68 Coupe 302 EFI swap
I am wanting to do a swap with a 93 302 Efi into a 68 Mustang Coupe. We are going to pick up the donor car this weekend. The fuel pump is bad on the donor car now. What electric fuel pump could I get that would work on the 93 to get it to run then use it for the swap on the 68???
Also, what else would we have to out source that can't be used from the donor? |
#2 | |
In the 68 if you want to keep your stock gas tank there are two things you need. First that fuel pump. Go to any auto parts store and get one for a 88 Ford F150 with the dual tanks. It's a factory external pump that cranks out about 90psi, and will cost you about 80 bux (if you find a better price more power to ya) It's a lot less than a performance aftermarket one and is more than enough for a stock to mild performance build. Second thing you will need to do is run a return line back, 2 easy ways with out molesting your tank. 1. Put a tube on the sending unit for the return line and it will just pump the fuel right back up there. (I have hear of this being done and no issues, I'm going this route on mine.) 2. The more dangerous route... run the fuel line up threw the trunk and into the filler neck. Danger here because you are sending a fuel line into the car. I don't recommend this one but I have heard of people doing it as well. I was cruse'n the forum and joined specifically to answer this question lol. Good luck and have fun
find out what the fuel pressure is suppose to be.go to the local auto parts store and buy an inline pump.dont foget to get an inline fuel filter to put back at the tank.i use the inline pumps for 5.0 ford pickups.1989 or later.
i sixing 200 six with 300 hp. |
Thanks for the info. Can i leave the old pump in the tank and put the inline pump in between the tank and engine. My question is, will it pull fuel through
the original pump that is bad inside the tank? |
Lost in the 60's
1968 GT 500 Super Snake
12.6 @ 114.3
Dont use the tank from the 93. Add a return trough the sending unit of your gas tank in the 1968.
Also Remeber if your trying to start the 93 and the 93 was in a wreck. there is a fuel pump kill switch that has to be reset in the trunk.
MustangOne's Car's![]() How to post Photos in Your Thread. Vote for your Favorite Ride of the month, Every Month Modded Mustangs Facebook Last edited by MustangOne; November 18th, 2009 at 10:37 AM. |
I am just trying to get the 93 to run. It only has 10 psi at fuel rail. It will crank spraying gas in the engine with a squirt bottle. Whst I am asking is ih I put an inline pump between the old pump in the tank and the engine, will it pull the fuel through the bad pump?
Thanks |
#7 | |
Lost in the 60's
12.6 @ 114.3
MustangOne's Car's![]() How to post Photos in Your Thread. Vote for your Favorite Ride of the month, Every Month Modded Mustangs Facebook Last edited by MustangOne; November 18th, 2009 at 12:30 PM. |
10-4
you can run the return to the filler line in the trunk.use a peice of 3/8 brake line and angle it through a drilled hole at a down angle.works good for me.make this a full steel line .
Haven't run it
do it right. sump the tank and run braided lines
01+ 04 GT. 67 Fstbk/90 LX
N/A
![]() iTrader: 1 reviews
Thats the way I'm going with my fastback swap. I'm using the Aeromotive rails and braided lines. The mustangdepot.com and autoworksracing.com (autoworks international) sell special EFI tanks for classic stangs. Check them out.
Threads Similar to: 68 Coupe 302 EFI swap
| 302 engine 2b to EFI | 302supercharged | Classic Mustangs | 3 | July 28th, 2009 09:40 AM |
| Engine Swap, '95 302 into a '70 302 | Altumdreams | Classic Mustangs | 2 | February 15th, 2009 12:09 PM |
| Help carb'ed 302 /efi 302 | sins23 | 5.0 Mustangs | 5 | September 10th, 2007 10:26 AM |
| 302 EFI 5.0 Engine | shurb125 | 5.0 Mustangs | 9 | January 10th, 2007 10:23 PM |
