LinkBack (2) | Thread Tools |
#1
92' Mustang 4cyl LX
351w in 68 mustang. help w/ HEADERS
were installing a 351 windsor in my dads 68 coupe.
the problem were having right now is that the headers dont fit. Which headers do i need?? i tried long ones, but im wondering if i need shorties or if the long ones will fit. |
Lost in the 60's
1968 GT 500 Super Snake
12.6 @ 114.3
Hello,
This is the set up I used on my 1968. This a 351W stroked to a 427. These are the Headers we use, fit and look great. Headman Elite Headers Here is what they Look like on my Motor... ![]()
i am doing a 351w swap in my 68 coup as well and im concerned about some issues that i cant seem to get the right answers for. i have a c4 auto and just bought a 2500 stall for it and plan on using my 28oz flex plate from my 289 as well as the harmonic. will it work on my 79 351w, 68 c4 combo? i have all others dist headman hedders and intake. any help would be great..thx
#4 | |
Lost in the 60's
12.6 @ 114.3
![]() If your 79 351 had the flex plate look at the weight and the tooth count 28oz = 157 tooth and 50 oz was 164 tooth count.. If there both the same as yours, it will be fine. what you have to watch out for is if you 1979 351 is a 50oz motor you will not be able to use the flex plate. I belive that the 50 oz motors started in 1980. but double check it just in case. I hope this helps. |
it didnt come with a flex plate at all. and the harmonic is a new one but i cant tell what size it is. and also the search i have done says its a 28oz till like 80 or 82. so if its a 28oz then my 289 stuff will work then right? i baught the motor as a new short block and the guy that had it built passed away so i dont know how it was set up so im taking a stab in the dark with 28oz.
Lost in the 60's
12.6 @ 114.3
You can go ahead and set it up as a 28oz. You should be safe. Even if it is a 50oz set up it will not hurt it to start and run it to see.
I belive it is a 28oz set up. and all your 289 stuff will work just fine. Good Luck. Let me know if I can help you anymore. |
1966, 1989, 1992 Mustang
I have a new set of 351 'swap' headers that I am not going to use. They are made for this application. They are shortys, and are ceramic coated. I sold the motor and am building a 302 instead, so I dont need these. Just let me know.
2 funny! i just sold my new hooker set that i ceramic coated and pollished for a 302. i do have a pair of of these just not coated. what would you want for them?
I need to get $250 for them. I paid $308, (have reciept), and that doesnt include shipping. Got em from jet hot coatings.
Did I mention that these were never even bolted up to heads?
so why didnt you continue to go with the 351w in your ride? is it because of the issues like im having? i havnt installed mine yet maybe by tue i will and prey that it works and doesnt vibrate all to hell on me.
The car had a 351 in it before, and ran GREAT! The car was sort of a beater, so I didnt really care about the rubbing going on against the shock towers. Yes, the 351 fits, but it WILL rub if you dont make more room. When I got the car painted, the engine bay got painted body color as well, so it looks just as nice as the outside. I couldnt spent that kind of $$ just to have the paint rubbed right off. So I figured a roller 302 with a charger on it will fit much better.
I dont think youll have a prob. with vibration. Itll rub, but you wont feel it while driving, I never did.EDIT; you have a 68, so you have more room between the shock towers, it might not rub. IDK.
yeah i think im a lil wider and i will be painting the engine bay later this year. i did the rest of the car myself too and was thinking of painting it the same as the outside. i like to do it in stages due to fundage and to make sure it all works before i lay paint on it. is yours cany red with a pearl white? i painted mine the base layer of a candy as with the darker stripes were a candy base. in the sun it will bring a tear to your eyes its so bright...lol! mission accomplished!
The whole car was sprayed in Orion silver, which is the base for the red, and the color of the stripes, then the stripes were masked off and then the car was sprayed red, which is House of Kolor candy apple red. Talk about bringing a tear to your eye, try $8500 bux for a paint job! And thats not even on the expensive side! Post pics of your car!!
ok i will try and see what i can do. its not as complete as yours but it looks good and people at the shows just love it. cant believe i painted it myself.
At least you have a project to work on.
Just remember, under construction is always acceptable.
i have to resize them first before this site will take them. too bad all the good ones are on a hard drive that doesnt work anymore....ugg!
okay guys i have another issue. im using the 351w harmonic with the 302 water pump and im trying to figure out wich pulleys i need to make it work without fitment issues? i only need a 2 groove setup. and a 4 bolt pattern on the harmonic. any sugestions? will a 351w pully setup work? or is their a spacing diference between the 302 pump and 351w pump?
Lost in the 60's
12.6 @ 114.3
The 302 and 351W set is the same.
You just have to use the same set up for Crank and Water pump pullys. |
is the water pump for the 351w a lil taller than the 302? i mean where the pully bolts to it ..it seems as if the 351 is about an inch taller torwards the hood???? i got some pullys to fit the 4 bolt harmonic but then it hits the water pump pully. the water pump pully is from the 289.... i cant seem to find a smaller diamiter one with the same spacing that i need.
Lost in the 60's
12.6 @ 114.3
The Timing chain cover for a 289,302,351W are all the exact same. I use a Water Pump from a 1968 302 on my 351W. Passenger side water outlet.
The crank pulys and water pump pullys are match sets. you can not use 1 of each from different years. Some of the crank pullys are bigger and water pump pully is smaller, and the other way around. Also some are deeper than others so the belt will not line up. You can use this Harmonic balancer and use you old pully set up. ![]() Link to Summit for part This is a 3 or 4 bolt balancer. Or the really Crazy thing is you can use your old balancer and save the $79 bucks |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/classic-mustangs/143034-351w-68-mustang-help-w-headers.html
| 351w in 68 mustang. help w/ HEADERS Wheat Blog | This thread | Pingback | November 10th, 2009 09:32 PM | |
Threads Similar to: 351w in 68 mustang. help w/ HEADERS
| Mustang 351w Problem | -Joeyy- | 5.0 Mustangs | 43 | September 16th, 2008 04:02 PM |
| best 351w swap headers with a c-4 | 92sspnotchback | 5.0 Mustangs | 1 | August 12th, 2008 10:19 PM |
| Different 351W headers | teal89 | 5.0 Mustangs | 12 | May 24th, 2008 10:50 PM |
| 351W headers? | gregkelley | 5.0 Mustangs | 4 | April 28th, 2007 11:14 AM |
