'95 GT
Was probably faster before I got it.
Roller Cam
So how do you install a hydraulic roller cam (like what's in the 5.0L 302HO's) in a 289 that runs the old flat tappet from the factory? What needs to be bought and done to make that swap possible?
Its red, long, and comes with an 8 foot bed attached. Wanna come play with it? ![]()
you can buy a kit that comes with cam, button spring ,bridged lifters, push rods, and roller rockers.most cam builders can set you up.may talk to mustangone and he might have a number.
i sixing 200 six with 300 hp. |
'95 GT
Cool. How much does a kit like that run. I'm trying to plan ahead and start saving some.
Lost in the 60's
1968 GT 500 Super Snake
12.6 @ 114.3
Here is the List of Roller Cams for your Motor. Roller Comp Cams
Here is a good kit for a Daily Driver Build $739.95
1969 Mustang Mach 1
6.824@101.61
You can use the link bar lifters and not have to have any machining done on the block. If you use standard roller lifters, the valley has to be machined for the spider/dogbone setup. The linkbars are a better setup, but will cost you about twice as much. The only other thing you will probably have to do, is trim the cam retainer plate to fit under the timing gear, and you'll have to go to a brass distributor gear.
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
'95 GT
Damn, sound's like craigslist won't be there for me this time. Well, I'd better start saving. Looks like the EFI is gonna have to deal with being the wrong cam setup for awhile. I know that it works with the old flat tappet cams, but I was hoping I could convert it so it'd be more accurate for the whole swap.
#7 | |
1964 1/2 Mustang Hardtop
I have a five bolt 289 in my 64 1/2 and I've done a bit of research. I've gone back and forth whether to build up my 289 (more $) or go modern (easier, much cheaper) I will more than likely go the more expensive route and build up the 289 as a roller/stroker as I will also get a new bellhousing for the five speed I plan to install as well. The "machining" for the spider/dogbone isn't much more than match-drilling two holes and then hand-tapping. And its much cheaper ($35.00 for the spider) than the link-bar setup($400.00 for the lifters alone). For what you're investing into the link-bar lifters, the economical choice would be to get a roller motor from a junkyard and build it. Cheers, Brian |
#8 | |
Lost in the 60's
12.6 @ 114.3
What we do is use the T-5 speed adapter plate to mount the 5 speed to your bell housing and use your clutch and z-bar set up. |
#9 | |
1969 Mustang Mach 1
6.824@101.61
And the machining also includes cutting a level area in the valley for the spider. I've done it more than once. Cheers
use the kit and the adapter mustangone suggested and you will be o,k.if interested i have a nice t-5.
'95 GT
No thanks, I'm looking for either a C-4 or a Top Loader. Transmission and I aren't really the best of friends so I want to try and keep that end of it as painless and simple as I can.
#12 | |
Bellhousing, QuickTime, 5 bolt SB Ford, T-5/TKO, cable release Brian |
#13 | |
Lost in the 60's
12.6 @ 114.3
Or is you car a auto? |
It's a C4 Auto. This project is still in the planning stages. It's going to be a while before I have the coin, so I'm trying to get the research out of the way. If I had all the money to do everything I want to do, I'd end up doing it twice. Lucky for me, the car is still a blast to drive daily as is.
The daily driver kit is very attractive BTW. Where can I read the specs? Is that from your site or Comp's? Thanks, Brian |
Lost in the 60's
12.6 @ 114.3
here is the spec's Comp Cams 270/270
Threads Similar to: Roller Cam
| 1.6 or 1.7 roller rockers with the e cam? | 80Cobra306 | 5.0 Mustangs | 8 | September 15th, 2009 01:14 AM |
| Solid roller cam??? | flamed 98 gt | 5.0 Mustangs | 26 | February 21st, 2009 03:03 AM |
