Check/Set Timing
Can any one tell me how to check the timing on a '66 Mustang, 302? What would be the setting for "correct" timing?
1969 Mustang Mach 1
7.324@94.61 N/A
You need a timing light. It would be kind of hard to explain to someone without showing them. There should be a mark on the timing chain cover, and there will be other marks on the balancer. Hook up the timing light, and put the clamp on the number 1 cylinder (front, passenger side) plug wire. Start the car, and aim the light at the balancer. Are there any mods? A cam can change what initail timing you would run.
![]() ProSystems Aeromotive TFS MSD Bullet Induction Solutions PA Moser |
#3 | |
not only that but your distributor also adds or takes away from the timing and getting into that is a bit more involved.
Official MM Zeppelineers. Crew member #1 - Captain
#4 | |
1969 Mustang Mach 1
7.324@94.61 N/A
#5 | |
well this summer i will post a how to on the distributor. mine needs to be removed and reseated. whoever built the engine just dropped it in wherever so it still needs to be advanced a little but can't because it is already bumping against the thermostat housing.
1967 Coupe
12.3 @ 115
Hmm 1 tooth off? That sux. I went with a Mallory unailite. It does'ent have one of thoes annoying vaccum advance tits on it. Did away with the points alltogether.
1969 Mustang Mach 1
7.324@94.61 N/A
Yeah mine has an MSD AL6. Points suck.
#8 | |
Threads Similar to: Check/Set Timing
| Timing Help Me | skid6 | 5.0 Mustangs | 3 | November 19th, 2007 10:42 AM |
| timing | hopper | 5.0 Mustangs | 3 | June 4th, 2007 07:54 AM |
| timing | B.A.M302 | 5.0 Mustangs | 4 | April 8th, 2007 06:36 PM |
| Timing | 94GTD1SC | 94-95 | 5 | February 25th, 2007 01:54 AM |
| Need to know timing? | 5.0 Rono | 5.0 Mustangs | 4 | July 10th, 2006 04:37 PM |
