Rebuilding engine
Could some give me an estimate on how much it would be to have someone rebuild a 289ci engine from a 68. Im talking about all new parts and even getting it bored out.
1969 Mustang Mach 1
6.824@101.61
It depends on what all would have to be done. If the engine isn't blown up, there would be no reason to replace everything, unless you're modding the hell out of it. Really all you should have to replace would be the pistons, rings, gaskets, and maybe get the heads rebuilt, or a valve job. The crank might be able to be turned, depending on how many times it's been done in the past. Your best bet would be to go to the local machine shop, and talk to them about it.
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
here is a rough idea. last i checked boring costed around 20 per cylinder. then depending on what you want with a rebuild kit around 700 for the most. then you have to think labor an all that fun stuff. so if you jus want it to stock i would say 1300 easy.
$1300 with the heads re-done unassembled.
Thanks Bill ![]() My Lug Nuts Have More Torque Than Your Honda !! |
Threads Similar to: Rebuilding engine
| Rebuilding 289, what to use for better HP? | nzmustang | Classic Mustangs | 12 | July 11th, 2007 09:59 PM |
| Rebuilding transmission? | gregkelley | 5.0 Mustangs | 1 | March 19th, 2007 09:09 PM |
| Finally done rebuilding the engine!!!!! | GotBoost232 | V6 Mustangs | 18 | January 3rd, 2007 11:03 PM |
| Rebuilding a Mustang | Horseshoeing | Classic Mustangs | 1 | September 2nd, 2006 05:56 PM |
| rebuilding engine... what should i get? | Ninjawafers! | V6 Mustangs | 2 | August 30th, 2006 08:49 PM |
