351w swap pully issues
Old February 9th, 2010, 12:16 PM   #1
68stang73 is on a distinguished road
im swaping a 351w in my 68 and i used a 302 water pump for the neck on pass side. and the 351w didnt come with pulleys and so im having issues trying to find what will fit on it. its a 4 bolt harmonic and its a 79 block. what will work so that the water pump pully i have from my 289 will fit with the harmonic im trying to find? or what should i do? on a budget and going to wrecking yard today to look??????
Old February 10th, 2010, 08:29 AM   #2
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
The Timing chain cover for a 289,302,351W are all the exact same. I use a Water Pump from a 1968 302 on my 351W. Passenger side water outlet.
The crank pulys and water pump pullys are match sets. you can not use 1 of each from different years. Some of the crank pullys are bigger and water pump pully is smaller, and the other way around. Also some are deeper than others so the belt will not line up.
You can use this Harmonic balancer and use you old pully set up.
Link to Summit for part This is a 3 or 4 bolt balancer. Or the really Crazy thing is you can use your old balancer and save the $79 bucks
Threads Similar to: 351w swap pully issues
351w swap into 00 v6 got poney V6 Mustangs 13 March 15th, 2011 05:58 PM
351w swap Lazor05 5.0 Mustangs 15 May 11th, 2009 07:47 PM
351w Swap shadowgames81 5.0 Mustangs 3 March 23rd, 2009 07:43 PM
best 351w swap headers with a c-4 92sspnotchback 5.0 Mustangs 1 August 12th, 2008 11:19 PM
Looking at doing a pully swap 86ttops 96-98 7 April 20th, 2008 10:11 PM
