69 Mach 1 – looking for answers about a 390 to 351w conversion:
LinkBack (2) Thread Tools
Old June 1st, 2010, 12:30 AM   2 links from elsewhere to this Post. Click to view. #1
69 Mach 1 S code
mcmenomy is on a distinguished road
Hi All,
I purchased a 69 Mach1 S code 390 with a four speed car and I want to replace the drive train for a 351W with an AOD, to make it friendlier for everyday city driving. I already know that I will need another transmission cross member, shifter to replace the four speed, and new pedals, but I’m not sure on the best place to find them. I also would like to know if I can use the mounting brackets for the alternator and power steering from the 390 on the 351. The 351 is out of an 84 bronco.
The reason that I’m replacing the engine is that I’m looking for something that I can drive everyday and not kill me at the pump. I’m also tired of having my toys stay in the garage and want to enjoy my 69 every day I can.
So, does anyone have experience on this conversion and what will be needed?
Old June 1st, 2010, 02:09 AM   #2
blown33 is on a distinguished road
no both engines a comletly differant you will need a differant water pump also
1988 mustang lx 373 upers and lowers
Old June 1st, 2010, 07:34 AM   #3
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
Welcome to MM Forum...
Yes,
The items on the motor Like alt, power steering pump can be used. The brakets are all different.
The motor mount are all different also.
If you like you can call me and I would glad to set you up with everything you need to do the swap.
I have the pedals, tran mounts, motor mounts, and brakets.
Be sure and save your old stuff to go back on your car when you like to swap back over.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/classic-mustangs/168208-69-mach-1-looking-answers-about-390-351w-conversion.html
Ford Mustang Mach 1 351 (1972) Info This thread Refback June 20th, 2011 11:45 AM
Thread 69 Mach 1 – looking for answers about a 390 to 351w conversion: | Forums at Modded Mustangs | BoardReader This thread Refback May 4th, 2011 03:05 PM
Threads Similar to: 69 Mach 1 – looking for answers about a 390 to 351w conversion:
Gt40 intake 351w or Trick Flow 351w Tyler2009 5.0 Mustangs 3 January 27th, 2010 09:40 PM
67 coupe I6 to 351W conversion help! stang67coupe Classic Mustangs 11 January 20th, 2010 12:03 AM
390 in a 67 or 94? Countryboy_99 Classic Mustangs 9 June 1st, 2009 08:16 PM
390 in a 67 koda 279 Classic Mustangs 9 June 1st, 2009 07:47 PM
390 hp with a s/c pr gt 2005 - 2010 46 January 13th, 2008 04:02 PM
