Engine Bay Painting Question
Old June 1st, 2010, 09:53 AM   #1
1973 Mustang Mach 1
SkotTTU is on a distinguished road
I have my engine out of the 73 Mach 1 and getting rebuilt. I will be rewiring the car later, but in the mean time I want to go through and repaint the engine compartment.
The car will not be a show car and I am doing this to just clean it up and make sure that rust is not developing (the car is from New Hampshire and the last owner did not store it well)
On a small side section, I started using a wire brush drill attachment to scrap off there paint and some stuck on grease/dirt. There was some discoloration in spots, but no rust holes or disinigration, when I got down to the metal. What is my best course of action?
I had planned on:
1. Wire brushing
2. Rust Reformer coat to take care rust/discoloration I could not scape to metal , then sanding (1000 grit)
3. Epoxy Primer, then sanding (1000 grit)
4. Black enamel, then sanding (1500 grit)
5. High gloss clear coat
Is this a good plan? Any advice? Space is a limiting factor and I have left the transmission and steering in place.
Thanks, -Scott
Old June 2nd, 2010, 12:08 PM   #2
2001 GT, 1965 coupe
tboz65 is on a distinguished road
Send a message via AIM to tboz65
Sounds like a good plan but are you going for a show quality finish, if not the 1000/1500 sandpaper is a bit overboard.
Threads Similar to: Engine Bay Painting Question
Best Way to Clean the Engine Bay and Engine. 04GTNAustin General Car Care & Detailing 29 April 21st, 2010 08:41 AM
custom engine bay painting question cuartza 2005 - 2010 11 August 25th, 2009 03:40 PM
Engine bay question squirt 5.0 Mustangs 21 October 23rd, 2008 11:08 PM
Washed n cleaned engine today.. pics of engine bay. MustanG_guy17 The Clubhouse 40 January 4th, 2008 10:14 PM
Engine Bay 00vabchgt Visual 4 March 15th, 2007 11:17 AM
