SN-66 Coupe
I've been woRKing on this for a little over a year now but haven't posted up here. I know this build has been done before with a bigger budget, SN65 fastback.
The 96 Vert I bought from Brandon, he had it listed on here for sale with front end damage. The 66 wheelbase is 6.7" longer than the 96. I'm leaving the engine against the firewall, but moving the suspension and steering forward. I'll have to extend the steering shaft and relocate the oil filter, which falls mid K-member once relocated. The engine will remain in the current K-member, I'll graft bits off another K-member to move the steering and suspension.
66 Coupe, Supercharged 408 Clevor, Viper T56, Cobra IRS 66 Coupe, Supercharged 03 Cobra drivetrain and suspension (project) 03 Viper, Supercharged |
Got these off MarkCore for this project.
Took some massaging but I got the K member in.
New front control arm bushings and ball joints for 96.
66 Front clip and firewall removal.
96 Rear end removal.
Finally got Bob his parts off the 96.
I also took the wheels and brakes off the Cobra, and took the vert roof off. I was going to give the roof away to a local father son project but accidentally tore the canvas. I still haven't told the father yet, ouch. I did notice the vert back glass has rear defroster element built in glass, and it looks almost same dimensions as the 66 rear glass, more to come on that. I like those wheels! With the 66 body over them, will definitely need fender flares again, box flares this time.
More progress:
There was a few spots where on the inner rocker panels that had remnants of floor and seat riser, got rid of them and cleaned the inner rockers up. Then I started on my stilts. I'm going to use thee to raise and lower the 66 body and to roll it around. It has to fit to the outside of the body so the 96 can roll under it. Not pictured, I cut the 66 dash out. The floor was crudely patched, it was held in with pop rivets. I'm taking held to the rocker panels with rivets. The more I dig up hidden fix jobs the more I feel good about destroying the car and realize this car was a perfect candidate for what I'm doing. It's soft in all the right places. I used the door hinge and welded it stuck in place. And the strike plate. My guess on the body weight as is, around 300 lbs. I spend the rest of The day carefully dismantling the 96 more. Got the pedals out, wiring harness, and a few other items. I want to get the AC box out but need the tools.
Didn't someone say you can't pull the engine without separating the tranny? Look, the starter is still connected too.
Haha, I still had to pull the engine K-member, seen below is the suspension K-member still bolted in. Everything I've taken off the 96 I have given away. I found a guy on the Vintage forums that have been through a rough time in the past 5 years since I he and I moved to Ohio. He's coming down from Akron this weekend, I'm giving him the engine, tranny, wiring harness and a lot of other stuff.
It's nice how 13 hours can be summed up into 5 photos.
Cut the tail pannel off the 96, shown in pics.
I also started trimming the 96 cowl in prep for grafting the 66 on.
I was shocked at how little was done but how much it looks like I did.
The rockers are lined up, I just need to weld them together and build a filler panel for the cowl.
Trunk/SN-95 rear bumper
Billy Weston
looks like a fun project.... make sure you keep us updated.
![]() TT Build in progress....... Need work done to your car for a great price in Hampton Roads? Shoot me a PM. |
Lost in the 60's
1968 GT 500 Super Snake
12.6 @ 114.3
Looks Great, I cant wait to see more of it.
Threads Similar to: SN-66 Coupe
| my new coupe.. | USMC8511 | 5.0 Mustangs | 12 | May 11th, 2010 11:33 AM |
| might be my new coupe? | sickfox | 5.0 Mustangs | 38 | June 24th, 2009 12:27 PM |
| 66 coupe - 85 GT | fstredford | Classic Mustangs | 1 | June 8th, 2009 05:20 PM |
| My '67 Coupe | 351w_stang | Classic Mustangs | 8 | May 26th, 2009 06:13 PM |
| May have a 67 coupe on the way. | metallicat | Classic Mustangs | 6 | May 24th, 2009 11:21 AM |
