what 5 speed trans fits on a 289
Ive got a 67 mustang all original when it comes to the drive train. Here in the next few months I am going to rebuild the motor and paint the engine bay. I would like to put in a 5 speed trans that does not take a lot of modifications. Also is there any transmissions that will work with my drive shaft or with any option am i going to have to get a new one.
A T5 out of a V8 foxbody Mustang will work. Some people have been able to do the swap without shortening the DS. You really won't know until you get to that point. I'm building a 68 now that we're dropping a T5 into.
66 Coupe, Supercharged 408 Clevor, Viper T56, Cobra IRS 66 Coupe, Supercharged 03 Cobra drivetrain and suspension (project) 03 Viper, Supercharged |
#3 | |
By the way love what you are doing with your stang
Lost in the 60's
1968 GT 500 Super Snake
12.6 @ 114.3
All you have to do is get a T-5 and use a adapter plate. and all the stuff you have already will work.
Just add this to your bell housing and done. Will have to slot the trans mount , and that is it. T5 has no computer.
MustangOne's Car's![]() How to post Photos in Your Thread. Vote for your Favorite Ride of the month, Every Month Modded Mustangs Facebook Last edited by MustangOne; September 6th, 2010 at 02:35 AM. |
So You are saying I dont even need a trans crossmember?
Lost in the 60's
12.6 @ 114.3
You can buy it if you like to. The old one just needs to be slotted 1"
#7 | |
Also what about a driveshaft?
Sometimes you need to shorten the driveshaft, sometimes you don't, just test fit when you're done. Average is 49.5" center to center on the u-joints, but not every car is exactly the same.
Lost in the 60's
12.6 @ 114.3
Yes we sell the plate, The drive shaft I would wait to see what you need.
We can use our stock one most of the time. |
Ok thanks I will get with you shortly after I find the trans and get that plate from you. Thanks again for the great info as usual
I used the T5 bellhousing and did not need the adapter plate.
My driveshaft only had .500 inches of freeplay. You should have .750 to 1.000 inches. I decided to use an aluminum DS that was 51 inches center to center. Aluminum reduces vibration problems. Pictures and Info: Drive shaft You want to get a world class T5. Here is info on how to ID a transmission if you are buying it: How to ID a T5 It is also recommended you change out the rear bushing and seal. It is also a good idea to change the aluminum bearing retainer to a steel retainer. Here is how to do it: BM Ripper Shifter and T5 upgrades | FordMuscle Magazine I decided to use a 10 1/2 inch King Cobra diaphragm clutch instead of the old 3 finger style. I needed to get a new flywheel with 28 oz imbalance, 157 teeth ($125 Ebay) so it would mount. I also put in a hydraulic clutch that works great. I did not want to deal with a cable clutch and heat issues. Cost was about $230. Info, parts list and pictures: Hydraulic clutch More info on the change out: T5 5th gear is a little tall with my 3.00 rear end. I find I need to down shift to 4th to pass quickly on the freeway so I wont lug the engine. I just bought a 3.55 trac-lok 3rd member I will be installing in the next few weeks so that problem will go away soon. Overall it is a great mod to do on a Mustang. Good Luck and BE Safe Ron
http://chris66dad.tripod.com/ Father Son Restoration A code 66 coupe 289 4v, Roller Rockers, Electric fan Performer & 650 Edelbrock MSD ignition Tri Y into 2.25 Shelby side exhaust T5 conversion and 3.55 Trac Lok Hydraulic clutch CSRP Discs Last edited by chris66dad; September 8th, 2010 at 02:10 PM. |
Threads Similar to: what 5 speed trans fits on a 289
| 1966, 289 with 3 speed trans. . wand to upgrade to 4 or 5 speed, any suggestions?? | HORSMEN1995 | Classic Mustangs | 6 | February 20th, 2009 03:23 PM |
| what about the Richmond six speed trans | gordon norris | 5.0 Mustangs | 44 | October 28th, 2007 12:46 AM |
| five speed manual trans | keeper | V6 Mustangs | 1 | August 3rd, 2007 02:05 AM |
| 6 speed trans in a GT | AF_COP | 2005 - 2010 | 9 | January 27th, 2007 03:01 AM |
| 6 speed trans in a GT | AF_COP | 2005 - 2010 | 1 | January 24th, 2007 04:38 PM |
