LinkBack (1) | Thread Tools |
#1
Replacement Radiator
I just bought a 68 289 2V coupe that is a driver but needs a new radiator. I bought this car in mind with replacing the entire drivetrain with a late model fuel injected motor out of 89 to 93. Does anyone know of a radiator I can put in now that will also work with the future drivetrain? Would hate to have to replace the radiator twice.
The foxbody radiator will fit but you will have to make your own mounts. I run one in both of my 66 Mustangs and the Falcon.
66 Coupe, Supercharged 408 Clevor, Viper T56, Cobra IRS 66 Coupe, Supercharged 03 Cobra drivetrain and suspension (project) 03 Viper, Supercharged |
What about if I used a good HiPo aluminum radiator that is meant for my car, would that also work for the 5.0 drivetrain? I know for my 289 the upper and lower hoses are both on the same side of the radiator but for the 5.0 water pump, not sure if they are the same. I know the upper hose on the 5.0 is on the same side as my 289 but not sure about the bottom.
#4 | |
Or just use a 1970 Mustang radiator with the 5.0 serpentine setup. Or, just use a bigger aluminum radiator for a foxbody. The foxbody radiator is a crossflow, it's better.
So I can swap the 289 water pump for a reverse flow 5.0 water pump and convert the 289 pulley system to a serpintine belt system? What about the radiator fan? Can I go with an electric fan and remove the engine driven fan all together or should I use a clutch driven fan? Thanks for helping out and providing answers...this is my first classic Mustang.
#6 | |
Just don't try to use the serpentine pulleys on the 70 pump nor the V-belt setup on a 5.0 water pump. Fan, go with an electric, but any and all will work. I thought you were going to swap everything from a donor car, engine/transmission/radiator. If that was the case just move everything over.
#7 | |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/classic-mustangs/182365-replacement-radiator.html
| Thread Replacement Radiator | Forums at Modded Mustangs | BoardReader | This thread | Refback | June 26th, 2011 12:07 PM | |
Threads Similar to: Replacement Radiator
| New radiator | fateisajester | 5.0 Mustangs | 12 | February 3rd, 2009 01:34 PM |
| Radiator | blackfox | 96-98 | 4 | August 10th, 2008 10:37 PM |
| replacement radiator support and fender apron where to buy | 92sspnotchback | 5.0 Mustangs | 2 | July 26th, 2008 10:05 PM |
| Radiator replacement | ByPopularDemand | V6 Mustangs | 2 | April 12th, 2008 04:58 PM |
