65 eleanor front end
Old September 18th, 2010, 06:45 PM   #1
65fstbk's Avatar
1965 Mustang Fastback
65fstbk is on a distinguished road
Hi i have a 1965 fastback and i want to put an eleanor kit on it but i dont like the 1965 E2 upper and lower nose section and i was wondering if i could put a 1967 upper and lower nose section on it
Old September 19th, 2010, 08:57 AM   #2
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
The problem is the the front fenders are at diffirent angles.
The 65 the streight, the 67 is angled. It would hard to do correctly.
Old September 19th, 2010, 12:25 PM   #3
65fstbk's Avatar
so do you think it is possible though i think the E2 front end looks a little strange
Old September 20th, 2010, 02:42 PM   #4
1965 ford mustang
britnjc is on a distinguished road
Anythings possible with a sawzall and bondo. question is do you want to put the time into it? Two totally different front ends, it would be a lot of work to mate. Also isn't the 67-68 wider on the nose also.You might be better off to try and mate the whole front clip from the 67 to a 65 to get it to look correct. That in itself would be a lot of work also.
Old September 20th, 2010, 03:20 PM   #5
Phatboy is on a distinguished road
Even putting an Eleanor kit on a 67 is hard enough. None of the aftermarket kits I have seen installed were done so easily at all. Tons of hours on body work to get them to fit correctly.
Compound that by having to modify your 65 to accept 67 components, unless you are an awesome body guy it may never fit right at all.
Anything is possible wtih enough money and time. You just have to decide how bad you want it. Is it worth 5-6-7000 dollars to have a "look?"
Old September 20th, 2010, 07:12 PM   #6
65fstbk's Avatar
actually they make a 1965 E2 kit and i dont have any problems with anything else on it i just dont like the front end on it so depending on how much work it is to fit the 67 front clip ill probably do that
Old September 20th, 2010, 11:00 PM   #7
1965 ford mustang
when I mentioned a front clip I didnt intend to make lt sound like they would bolt up. It will be anything but that you will need some master fabricator skills to make it look right, but possible with panel shaping on the fenders and a lot of cutting welding and engineering. I would just stick to the stock look. I love a 65 front end unmolested. Its amazing what a nice stance will change the lookof a car. here is a pic of mine
Old September 21st, 2010, 10:52 PM   #8
65fstbk's Avatar
I understand and i didnt intend on it bolting right on i just really want that look and i have lots of time so i can work with it plus i know a guy that specializes in mustang body work so he may be able to help me
Old September 28th, 2010, 06:43 PM   #9
65fstbk's Avatar
Question
i got to thinking and i was wondering would it be easier to just modify the 65 front end to look like the 67?
Threads Similar to: 65 eleanor front end
Back end sitting lower than front end? Blown 97 GT 96-98 31 October 21st, 2009 03:45 PM
Front end help 03 R Code 99-04 46 November 29th, 2007 09:33 PM
Front-End Stangzilla 5.0 Mustangs 44 March 20th, 2007 07:34 PM
Where can I get this front end? fallstar01 99-04 14 August 7th, 2006 05:46 PM
Front End ttop5.0 All Other Vehicles 0 June 28th, 2006 09:03 PM
