385 series 460 engine in a 1969 Mustang.
Old September 24th, 2010, 01:27 PM   #1
Jon1030 is on a distinguished road
Lemme start off by saying that I've always been a Honda guy, and I know little to nothing about anything else BUT Honda/Acura. Lol. But I'm trying something new, so bear with me for a while, as I'm sure stupid questions will arise.
My friend gave me two 460 engines. Both engines are good, supposedly, but I haven't looked at them yet. They're out of a couple of F250 trucks, but he wants to put a 7.3 diesel in those trucks, so he has no need for the 460 motors.
I wanted to know what I could do with these if I did completely rebuild them. I did a little searching, and I found that there have been several people that have put them in a '69 Mustang. I was wondering how difficult this would be and if it's a popular build. Any specific mods that have to be done before I can drop the motor?
Old September 24th, 2010, 03:22 PM   #2
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
Welcome to MM Forums...
With the heads the 460 has on them they will just fit. All you need is 1969 429 motor mounts.
Old September 25th, 2010, 12:59 AM   #3
Awesome. So no mods whatsoever? What about a higher rise hood? This is great, though. I'm glad it takes little to no mods. Definitely a relief. Are there any build threads for a 460 in a 69 mustang on this board?
Old September 29th, 2010, 10:30 AM   #4
1972 Mustang Convertible
TonyRumore is on a distinguished road
I did it in 1985 when I was 19. Maybe it is easier today, but back then it was a real pain in the ass. The '69/429 motor mounts that I had, moved the engine way forward in the bay. If the motor is not moved forward, you won't be able to get the starter to clear the steering rods. That puts the water pump right up against the radiator. Even using a Thunderbird/Thunderjet pump, which has a shorter snout, you won't have enough room to run a conventional fan. You need to use electric fans mounted to the front of the radiator. Even with the stock cast iron exhaust manifolds, they will be right up against your shock towers. You can still get the spark plugs out, but you have to use a socket with a hex on the back of it and reach down with an open end wrench to turn the socket. Then you have to come up with radiator hoses that will work. You'll have to sort through a pile of them to find something that will line up correctly with the motor and radiator. Then you have to make your own transmission mount, since it is moved forward as well. Then you have to get a drive shaft made.
Tony Rumore
Tromix
Old October 6th, 2010, 02:24 AM   #5
the 460 in a 69 doesn't sound like something I want to tackle at the moment. I do want to build a 69 mustang though. I read that there were 7 different engines offered in the 69 mustang. Which of these engines would offers the most power but isn't hard to find?
Old October 6th, 2010, 02:44 AM   #6
Nevermind. Found an amazing spec site for the 69. If anyone else wants to give it a look, I posted the link at the bottom.
According to the spec site, the 429 has the most power with 375hp. According to another site, though, Ford only made just over 1300 of th mustangs with the 429s in them, which seems like it would make it difficult for me to find one. However, I haven't read anything about the 428, which according to the site had the second most power with 335hp (Before being bored and fitted with newer high compression pistons, of course). How easy would it be for me to find a 428? And what transmissions can be used? I want a manual. 3spd or 4spd?
1969 Mustang
Old October 6th, 2010, 09:45 AM   #7
Lost in the 60's
MustangOne's Avatar
12.6 @ 114.3
I was thing we were using a 460 it was close to free...
Now if you are Looking to spend the kind of money it would take to buy a 428, 6k to 10k
Now we are in a total different ball park.
I would go with the New 351W Stroker motors, They are a lot cheaper and better than the old FE for the price.
Here is were you can get a great motor for low cost.
You can get a 424 stroker motor for $2395.
pawinc.com
Threads Similar to: 385 series 460 engine in a 1969 Mustang.
the 1969 mexican mustang vfast The Clubhouse 17 April 26th, 2011 04:59 PM
My 1969 Mustang Grande 351Grande Classic Mustangs 12 December 13th, 2009 12:49 AM
Fe engine family, 385 series, or 351W Quarters97gt Classic Mustangs 10 July 4th, 2009 03:26 AM
1969 Mustang Mach I UnderAlias Classic Mustangs 3 May 20th, 2008 08:53 PM
