Steering fix?
Old September 27th, 2010, 08:28 PM   #1
Look Ma! My First Post!
ThisIsMikey65's Avatar
1965 Mustang Fastback
Unknown... For now
ThisIsMikey65 is on a distinguished road
Steering fix?
I recently installed a Grant Classic steering wheel on my 1965 mustang and ever since the install, when ever I turn the wheel there's a grinding noise. I assume its coming from the wires and everything behind the horn button, but is there any way I can fix this? (Manual Steering)
And the sleeve that keeps the steering column solid keeps popping out. So my steering wheel is loose. Any advice would be much appreciated.
Thank you
Michael
Old September 28th, 2010, 08:40 AM   #2
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
Welcome to MM Forums...
It does sound like you are missing the spring that goes behind the steering wheel.
With out it, it will let the rod move around , not space the wheel out and mess up your turn signal wiring up like you discribed.
Old October 1st, 2010, 10:38 AM   #3
latamud is on a distinguished road
It could also be the 2 spring loaded horn pegs. They ride on a copper ring and sometimes they get worn down and make a grinding noise. Replace or maybe run some dielectric grease on there.
66 Coupe, Supercharged 408 Clevor, Viper T56, Cobra IRS
66 Coupe, Supercharged 03 Cobra drivetrain and suspension (project)
03 Viper, Supercharged
Threads Similar to: Steering fix?
How to fix the power steering pump whine? sk_idLA V6 Mustangs 23 January 26th, 2012 11:15 AM
Help with power steering to manual steering conversion Alucard2008 94-95 3 April 20th, 2011 06:12 AM
power steering to manual steering swap necro5.0 5.0 Mustangs 14 March 25th, 2010 10:57 PM
POWER STEERING PROBLEM FIX ! EDDNIE V6 Mustangs 3 April 7th, 2007 11:22 PM
Decreasing power steering pump pressure for tighter steering 83 5.0 5.0 Mustangs 6 January 7th, 2007 08:24 PM
