351W How to: crank bolt removal/and other
Old October 8th, 2010, 01:02 AM   #1
britroger is on a distinguished road
I originally started this resto project to fix my overheating 351W (1969 mustang 2dr coupe), and now i have most of the engine apart. I am trying to close all the doors on possible overheating causes. I am down to the heads and im trying to remove the timing chain cover. I want to ensure that there is no rust clogs in the block. I discovered a rusty paste substance in the passenger side head inside the port closest to the firewall (small bits of metal in the paste) This paste is probably because the car sat for 5 years and that is where the radiator fluid settled, tho i am not sure as the other 3 main ports are clean. What else could this be??
How do i stop the crank from moving/turning the engine over when i try to loosen the 1" crank bolt?? is there a special tool i could rent??
I have tried the 20" breaker bar and am wondering if it is worth the cost to get a heavyduty impac wrench or if that will even work. I will not use the cranking the starter method. Everything from the heater core to the radiator will be new.
Old October 8th, 2010, 01:24 AM   #2
Proud American
MustangMatt96GT's Avatar
I have always used an impact.... but you can also get a piston stop and it will hold the engine in place and will allow you to loosen the crank bolt. to pull your heads you dont need the timing cover off, but if you wanna put a new chain on( I would) then you would.
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old October 8th, 2010, 01:37 AM   #3
latamud is on a distinguished road
It's a 15/16" bolt. I have a $50 electric impact gun that I use to break the bolt loose.
66 Coupe, Supercharged 408 Clevor, Viper T56, Cobra IRS
66 Coupe, Supercharged 03 Cobra drivetrain and suspension (project)
03 Viper, Supercharged
Old October 8th, 2010, 02:46 AM   #4
thanks for the info on the size of the bolt, i was using a 1"socket and it was ok, yes im aware that the timing cover doesnt need to be off to remove the heads, but since i have the engine tore apart i might as well be through and replace the timing chain too, the timing chain cover is blocking my view of the engine block ports. I want to see if anything may be blocking those engine ports.
Old October 13th, 2010, 12:38 PM   #5
1970 Mustang Mach !
kevin70 is on a distinguished road
Send a message via Yahoo to kevin70
use an impact wrench to loosen crank bolt
Kevin
Threads Similar to: 351W How to: crank bolt removal/and other
351W 1969 Crank MustangMatt96GT 5.0 Mustangs 0 March 10th, 2010 06:10 PM
crank bolt moosenuk17 99-04 8 April 18th, 2009 06:04 AM
351w crank 88_FiveOh 5.0 Mustangs 8 March 16th, 2009 02:57 PM
HELP! SOHC 6 bolt crank/ cobra 8 bolt crank interchangability? the1968jeepthing 99-04 2 September 29th, 2008 11:39 PM
351w with a 302 crank? 68351w Classic Mustangs 4 July 4th, 2007 12:29 PM
