Threaded hole above fuel pump on 351C
Old October 22nd, 2010, 12:51 AM   #1
1973 Mustang Mach 1
SkotTTU is on a distinguished road
I noticed a threaded hole above the fuel pump and was wondering if this had a purpose or if I could just plug it up? Any ideas or ways to plug it up? It is bigger than the oil pressure or temp sensor hole.
The engine is 351C 2v. It is from my 73 Mach 1.
Thanks,
Old October 22nd, 2010, 08:49 AM   #2
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
I'm looking and dont see what you are looking at. in this photo do you see it?
Fuel pump area...
Water pump area...
Old October 23rd, 2010, 01:27 PM   #3
1973 Mustang Mach 1
My mistake, my spatial directions suck. It is the hole to the right of the fuel pump opening. Between the pump and the oil filter.
Is that a plug that you have in it?
Thanks,
Old October 24th, 2010, 11:51 AM   #4
Lost in the 60's
MustangOne's Avatar
12.6 @ 114.3
That is a a place you can put a oil sender at. On the 351C we put it on the block behind the intake.
Old October 26th, 2010, 09:24 AM   #5
BOLDT's Avatar
'68 Fastback GTA Restomod
BOLDT is on a distinguished road
I believe you are referring to the oil pressure port, you should consider running an external oil line from this port to the pressure port at the back of the block, with a tee at the back of the block to mount your sensor, provides better oiling on the 351c
Old October 26th, 2010, 12:40 PM   #6
BOLDT's Avatar
Old October 28th, 2010, 09:53 AM   #7
1973 Mustang Mach 1
BOLDT,
Is that just basically putting threaded nozzels into the sending holes and then connecting the two? Do you still have a pressure gauage then?
Old October 28th, 2010, 11:35 AM   #8
BOLDT's Avatar
yes, thats right, connect the front and back ports to provide more oil to the back of the block. place a tee at the back of the block for pressure sensor/gauge, I have a mechanical gauge in the engine compartment and an electrical in the dash.
Threads Similar to: Threaded hole above fuel pump on 351C
Datalogging Fuel Pump Volts with a BAP and Fuel Flow Rates Trick Tuners 99-04 21 November 18th, 2010 08:44 PM
Boost-A-Pump or GT500 Fuel Pump? stanglifemike 2005 - 2010 64 September 21st, 2009 01:17 PM
Fuel pump question. Stock GT pump to GT (supercar) pump. Nate's4.6 99-04 15 May 14th, 2008 02:25 PM
threaded insert ryans88gt 5.0 Mustangs 5 January 19th, 2008 11:55 AM
