68 coupe& 04 mach 1
67 fit 68 for 5 lug conversion
i have located a 67 coupe 5 lug car for my 68 coupe which is currently a 4 lug, will the 67 parts fit on a 68 to do a 5 lug conversion?
all the info i can get before i buy the 67 would be very helpful |
Lost in the 60's
1968 GT 500 Super Snake
12.6 @ 114.3
Yes the things you need will cross over just fine.
The 67 has diffrent lower control arms but you use yours instead. The steering will cross over, it will be nice it the steering box on the 67 is a rag joint one also. |
68 coupe& 04 mach 1
?'s
are there any other years that just bolt in to the 1968 coupes?
2001 GT
Spindles are the same so you just need the 5 lug brake setup. Steering for I6 and V8 were the same for 67-68.
67 Spindle - Disc and Drum were the same spindle 68 Spindle - Drum uses 67 spindle, Disc is different spindle
68 coupe& 04 mach 1
would a 69 coupe use the same parts rear end,front end?
2001 GT
1969 Drum and disc brake spindles are different. Drum spindles are the same as 1967-1968. Disc spindles are the same as 1968. So they should work.
Lost in the 60's
12.6 @ 114.3
the 1969 is the most like a 1968 of all the Mustangs.
68 coupe& 04 mach 1
more ?'s
if i have done my research right a cougar would also work or am finding some wrong information?
68 coupe& 04 mach 1
Threads Similar to: 67 fit 68 for 5 lug conversion
| easy rear 4 lug to 5 lug conversion | coolcatz | Classic Mustangs | 0 | April 17th, 2010 05:42 PM |
| 4 lug to 5 lug conversion | 90fastang | 5.0 Mustangs | 7 | December 20th, 2009 10:29 PM |
| Five Lug Conversion! | Olita 1 | 5.0 Mustangs | 23 | December 26th, 2007 10:35 AM |
| 5 lug conversion | notsoslo5.0 | 5.0 Mustangs | 8 | February 6th, 2007 07:26 PM |
| 4 lug to 5 lug conversion questions | jharp59 | Classic Mustangs | 0 | June 10th, 2006 10:44 PM |
