351C start-up Help needed
Old November 6th, 2010, 01:26 PM   #1
1973 Mustang Mach 1
SkotTTU is on a distinguished road
I have a rebuilt 351C 2v with an Edelbrock Performer Intake and 1406 carb. There are good sparks coming through to the spark plugs. When I try to start the car, it turns and almost starts to run, but just doesn't quite make it. Occasionally it will backfire and blow through the top of the carb.
Any advice? We re-timed the engine but using a straw in piston 1 and then rotating until top dead. Then, to get the distributor seated, we turned the engine until the distributor would sit. We adjusted slightly for the amount of rotation that was caused when the gears fully set.
Any help would be greatly appreciated.
Old November 6th, 2010, 02:31 PM   #2
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Sounds like it's possibly a timing issue. Have you checked and rechecked the firing order?
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old November 6th, 2010, 05:30 PM   #3
1973 Mustang Mach 1
We checked the timing and we are getting it to almost kick into running. We replaced the starter and retimed, but each time it gets close to firing but does not. I will try to post a video of what it is doing, maybe that will help.
Thanks,
Old November 6th, 2010, 11:07 PM   #4
BOLDT's Avatar
'68 Fastback GTA Restomod
BOLDT is on a distinguished road
pertronix?
Old November 7th, 2010, 07:48 PM   #5
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
what cam you have, witch firing order are you using ? try the other one.
Threads Similar to: 351C start-up Help needed
GT won't start. Help needed. danas96cobra 96-98 4 September 15th, 2009 07:48 PM
351c stang87 5.0 Mustangs 4 May 2nd, 2009 10:50 PM
351c pettydvm Classic Mustangs 45 February 15th, 2008 10:54 AM
351C rjhurtu 5.0 Mustangs 1 April 9th, 2007 09:12 AM
351c in a 96 v6 possible? 94v6blkndred V6 Mustangs 1 April 8th, 2007 11:43 PM
