1969 Mustang Mach 1
6.824@101.61
4 speed toploader qestion
I don't have much experience with these transmissions, but do some of them have hydraulic clutches, and some have manual? I'm pretty sure mines a manual clutch...at least it feels like it is. My throwout bearing is going out and this is what I found.
http://www.4speedtoploaders.com/shop/enter.html Throwout Bearings 1 1/16 inch bolt on hydraulic throwout bearing 1304 $372.14 3.000 lbs 1 1/16 inch bolt on hydraulic throwout bearing 1 1/16 inch bolt on hydraulic throwout bearing with master cylinder 13045 $465.00 5.000 lbs 1 1/16 inch bolt on hydraulic throwout bearing with master cylinder 1 3/8 inch bolt on hydraulic throwout bearing 1305 $372.14 3.000 lbs 1 3/8 inch bolt on hydraulic throwout bearing 1 3/8 inch bolt on hydraulic throwout bearing with master cylinder 13055 $465.00 5.000 lbs 1 3/8 inch bolt on hydraulic throwout bearing with master cylinder McLeod 1 1/16 inch throwout bearing 16031 $61.29 2.000 lbs McLeod 1 1/16 inch throwout bearing McLeod 1 3/8 inch throwout bearing 16042 $62.00 2.000 lbs McLeod 1 3/8 inch throwout bearing I though they were all manual, and this place rebuilds some for racing applications. Maybe the hydraulic is for those??????? anyways, I hope my throwout bearing is the cheaper ones.
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
If your car has been converted to a hydraulic throwout bearing then you dont need the whole kit just the hydraulic throwout bearing. A normal throwout bearing is more then likely what you need it goes on the clutch fork. $29.95
http://www.mustang-unl.com/itemdy00.asp?T1=N1439+01
Thanks Bill ![]() My Lug Nuts Have More Torque Than Your Honda !! |
1969 Mustang Mach 1
6.824@101.61
That what I was wondering. None of them came hydraulic right?
They have to be converted? I though that's how it was, but I just wanted to make sure.
Threads Similar to: 4 speed toploader qestion
| 4 speed toploader in fox | ih8chevy | 5.0 Mustangs | 5 | March 9th, 2007 11:13 PM |
| the NEED for SPEED | trueballerisme | V6 Mustangs | 14 | February 26th, 2007 01:02 AM |
| new guy on the block, new qestion | 73gt | V6 Mustangs | 12 | February 10th, 2007 10:52 PM |
| Supercharger / Turbo Qestion | droppedbass87 | General Tech | 18 | October 2nd, 2006 03:40 AM |
| AOD --> Toploader | Justin66GT | Classic Mustangs | 3 | September 12th, 2006 11:30 PM |
