LinkBack (1) | Thread Tools |
#1
turn signal/brake light problem
I purchased a 65 Mustang recently that had electrical problems. My current issue is the turn signal not working. When I turn on the lights the auxillary brake lights come on fine. When I step on the brakes both lights come on bright. When I turn on the turn signal to either side with the brakes on, the bright light goes out (auxillary light stays on). The blinker does not blink either during any of this. My initial thought was that the blinker relay was out. I purchased a new one and that did not fix the problem. Now I am lost as to where the problem is. PLEASE HELP!!
Lost in the 60's
1968 GT 500 Super Snake
12.6 @ 114.3
Welcome to MM Forums...
can you turn the signal on and work at anytime? The Auxiliary brake light? do you mean the park light lights? |
Blinkers do not work at all.
No, the blinkers do not work at all. The only way I know there is some sort of connection to the back lights is by applying the brake lights and then turning on the turn signal. By doing that it turns off the bright brake light with the blinker to that side on. This is what caused me to replace the turn signal relay/fuse.
problem fixed
after many hours tracing wires I finally figured out the problem. I have to order a new turn signal switch, the old one went bad caused by a short in the left front turn signal light. The spring holding the ground wire in the light was making contact with the other wires and causing a short. What a pain!
LinkBack to this Thread: http://www.moddedmustangs.com/forums/classic-mustangs/194506-turn-signal-brake-light-problem.html
| Thread Need help with turn signal issue | Forums at Modded Mustangs | BoardReader | This thread | Refback | December 11th, 2010 10:31 PM | |
Threads Similar to: turn signal/brake light problem
| 99-2004 brake and turn signal mod (make all three sections light up instead of two) | Saleen0101 | 99-04 | 12 | August 16th, 2010 10:09 AM |
| Turn signal not working when brake is on? | Fox2102 | Audio/Video | 13 | February 25th, 2008 08:45 PM |
| brake light/turn signal probel | jim.munoz | V6 Mustangs | 2 | October 20th, 2007 05:18 PM |
| Turn Signal Light | BoomerSixZero | Classic Mustangs | 6 | June 10th, 2007 08:17 AM |
| Turn Signal Light | themav46 | V6 Mustangs | 4 | September 30th, 2006 10:09 AM |
