95 302 into 67. Whats all needs to be done?
Old December 11th, 2010, 09:08 PM   #1
FastRidesOnly.com's Avatar
04 Cobra
FastRidesOnly.com is on a distinguished road
after i drop the 95 5.0/tran in the 67... what all do i need to do to get the car finished and running?
run the fuel lines to the trunk
mount the 95 computer
relocate the battery to the right side
mount the fusebox under the engine bay?
run wires to the 67 ignition (any advice on this)?
mount the 95gt fuel pump/sending unit in the 67 tank?
swap the fuse box thats under the 95gt dash?
do i use the 67 radiator or the 95 radiator/fan?
2004 SVT Cobra 281 M6 · 498.5 RWHP·Stiegemeier Stage 4 Ported M112 Supercharger·Steeda 2.81 Pulley·MotoBlue Pulleys+more
1967 Mustang 306 EFI M5 · 2003 GT 281 M5 · 1997 GT 281 M5 · 1987 GT 302 HO M5 · 1993 Z28 355
Old December 12th, 2010, 12:23 PM   #2
April 2010 ROTM
67svtstang's Avatar
1967 Fastback
67svtstang will become famous soon enough
Your biggest obstacle is going to be running the fuel lines and installing a fuel sending unit with two fittings on it. Surely somebody makes one by now, but i am not sure. You will also need a fuel pressure regulator. I recommend using -6an stainless steel braided line and fittings.
Wiring is pretty straight forward these days. You can buy an aftermarket harness for around 500.00 that eliminates the salt and shaker plugs that often have connection problems. If you are on a very strict budget and you are using the stock wiring, it still should be pretty easy. Just make sure all of the connectors inside the "salt and pepper" connectors are nice and tight. You can expand or reduce the female connector size with a pick if need be.
Other than that, it should be pretty straight forward. You will need to have someone weld new connectors onto the exhaust for headers, but it shouldnt be a big issue.
Old December 12th, 2010, 08:57 PM   #3
04 Cobra
thanks. i'm not sure if 95s had the salt shaker plugs.
Old December 13th, 2010, 03:08 PM   #4
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! has a spectacular aura aboutmustangmike! has a spectacular aura aboutmustangmike! has a spectacular aura about
Good luck man, one of these days ill get back to working on me 67 im thinking 351 or 302EFI to start with. Might stroke it and F/I, may not. Thats a long way away though ...
227whp N/A V6
Now w/ 8th Mile 8s !
How To Jmod Your Late Model 4R70W
Old December 19th, 2010, 12:06 AM   #5
65 Fastback
JamesW is on a distinguished road
I don't recall all the differences between installing a 92 and a 95, but...
- setting up your fuel pump system, either an in-tank or an external surge system, is a bit time consuming
- battery to either the drivers side or the truck
- better to mount the fusebox and relays inside the car
- use your 67 radiator, a flex hose at the bottom, and you'll have to fab your upper hose. I used two different hoses and an inline filter
Got some helpful info on my website on doing this
JamesW's Website
Old January 18th, 2011, 09:17 PM   #6
Look Ma! My First Post!
crickifur is on a distinguished road
I was just turned onto fordfuelinjection.com, they have a whole write up there on exactly what needs to be done. It does seem that the 89 to 93 models are the easier swap though....
Old January 18th, 2011, 09:18 PM   #7
Old January 22nd, 2011, 11:38 PM   #8
04 Cobra
thanx
Threads Similar to: 95 302 into 67. Whats all needs to be done?
Engine Swap Help Needed '70 302 to '95 302 Altumdreams Classic Mustangs 1 June 13th, 2010 05:44 PM
Whats the cheapest way to get a 302? Youngstang57 2005 - 2010 19 February 14th, 2010 10:02 AM
Engine Swap, '95 302 into a '70 302 Altumdreams Classic Mustangs 2 February 15th, 2009 11:09 AM
Help carb'ed 302 /efi 302 sins23 5.0 Mustangs 5 September 10th, 2007 09:26 AM
Weight of Dart sportsman 302 compared to stock 302 painfully slow 5.0 Mustangs 3 February 23rd, 2007 04:47 PM
