motor mounts for 67 mustang
Old December 13th, 2010, 07:31 PM   #1
1967 mustang coupe
ma67cpe is on a distinguished road
Send a message via Yahoo to ma67cpe
Does any body know where I can buy the motor mounts for my 67 mustang coupe. I see that the 67 is the only stang that is different. thanks for any help
Old December 13th, 2010, 11:36 PM   #2
1967 mustang coupe
this is what problem Im talking about
After 11/1/65, The design changed completely. The frame brackets were stamped steel, and the insulator and upper bracket were all one piece (marked C6OE or aftermarket #2257). There was no left or right insulator, the same part was used on both sides. Also after 11/1/65, the unique 289HP mounts were discontinued, all 289 engines used the same mounts.
The most confusing aspect was when Ford altered the angle of the insulator in 1967, which required a new insulator (marked C7ZE or aftermarket #2286) and bracket assembly. This altered the mounting angle of the insulator, to control vibration. Oddly, the 67 frame bracket was compatible with either the 289 engine, or the 390. The bracket varied in the location of the outer bolt hole. This pattern, traced from actual Ford brackets, can be used for identifying brackets, and can also be used as a pattern for drilling when printed out the proper actual size.
In 1968, Ford changed the design again, altering the bracket on coupes and fastbacks to use the 66 style insulator, but retaining the 1967 design in convertibles. This continued through 1970. Oddly, the 1970 BOSS 302 used the 1967 configuration.
Great care must be taken when replacing motor mounts. Although many suppliers offer a correctly-numbered mount for the 1967 design, it has in fact been replaced with the 1966 design, and will not fit properly. Glazier Nolan can provide mounts which fit the 1967 design.
One common misconception is that convertibles had the engine mounted at a different height than coupes. This is a result of force-fitting the incorrect mounts. The convertible mounts were intended to provide the same installed height. The early/late 66 mounts should also result in the same installed height.
Old January 5th, 2011, 11:20 AM   #3
Phatboy is on a distinguished road
Excellent information. Thanks!
Old January 6th, 2011, 01:34 AM   #4
Countryboy_99's Avatar
'95 GT
Was probably faster before I got it.
Countryboy_99 is on a distinguished road
Cliffnotes?
Its red, long, and comes with an 8 foot bed attached. Wanna come play with it?
Old January 6th, 2011, 09:06 AM   #5
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
I have some that I just took off a 1967 Fastback that I am installing the TCI front end.
Must people didn't know this about the 67's, Nice lay out on the info.
Threads Similar to: motor mounts for 67 mustang
mustang POLYURETHANE motor mounts 1hatch 5.0 Mustangs 8 August 15th, 2010 07:38 AM
Motor Mounts help! 97mustanggt 4V / SVT 11 April 29th, 2010 02:16 AM
motor mounts? 96_5.0_Mustang 5.0 Mustangs 6 February 22nd, 2010 02:58 PM
motor mounts drop mounts.. e3sean 5.0 Mustangs 9 February 11th, 2008 01:22 AM
Motor mounts Pony_with_an_attitude 5.0 Mustangs 3 July 25th, 2007 10:52 PM
