#201 | |
MM's king of Neon's
404 - car not found
17.81@87
If you do go back and touch areas up with body filler, you'll have to sand back down to bare metal before application. That was one of the cardinal body work rules I was taught, bondo should be applied to nothing but bare sanded metal. Then you get to sand it flat, prime it, and feather the edges back into the first coat of primer. Not always so bad, then you get to learn how to feather, which is valuable when doing spot painting. Just for future reference, here's the sequence of events I usually use: metalwork, coarse body filler, lightweight body filler, high build/filler primer, primer, color, clear. With copious amounts of block sanding in there of course. I don't know if you already knew this, but I just want to make sure you don't end up laying bondo on top of primer, and see a chunk of your paint fly off when you're driving down the road some day.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
#202 |
Noted, though epoxy is an entirely different animal than regular primer, technically I still need to weld shut the body trim holes so I will be stripping the epoxy to bare metal to weld those, then grinding the welds down flush, then bondo on to bare metal as you pointed out, then epoxy, then build primer, yaha, yada yada
though as with most things in the automotive industry there are two schools of thought on the subject of body filler on bare metal vs body filler on epoxy primer, enough so to warrant guys doing comparisons such as this one, a bit extreme testing methodology if you ask me but worth sharing Epoxy or No Epoxy Under Filler - Autobodystore |
#203 |
'95 GT
Was probably faster before I got it.
That is some good looking metal.
I was sent a dvd from hot rod all about body work and sheet metal prep. Makes me actually do some stuff like this, not to the scale you are. But like a just do an individual panel for someone or something.
Its red, long, and comes with an 8 foot bed attached. Wanna come play with it? ![]()
#204 |
you make it look so easy wish my 65,70 and 88 where going that easy lol
#205 |
Dude where you at? I have been following this for about 5 weeks now and you disappeared for 2 weeks? Good stuff!
#206 | |
1968 289 H20 |
#207 |
Look Ma! My First Post!
1968 Mustang Coupe
I have a 68 also. i did the motor work, now it's time for prime and paint. Since you have experience now, wanna do mine?? j/k i will be referring to your posts. thank you. and oh yeah, bump bump for optimus!!
#208 | |
#209 | |
#210 |
Now we can all follow along, you've become quite the popular poster man, I'm glad to be able to say that I knew you when you were just a nobody with the rusted roof issue,...now you're a somebody with a pretty good following.
You'll probably be needing your very own forum,...Gregski.com,...can I be a Mod,...please?
#211 |
1966 mustang I-6
Great write-ups! I can't wait now to start on mine. Reading that you live in Sac gave me even more inspiration. Thanx. Hope I can see your car in person some day.
Threads Similar to: Optimus Prime - The '68 Coupe
| 5.0 gt to 4v coupe | mailman400 | 5.0 Mustangs | 9 | October 2nd, 2010 03:59 AM |
| fuel pump will not prime! | tla280 | 5.0 Mustangs | 5 | June 3rd, 2010 02:33 PM |
| Fuel pump prime period | lawson4323 | 5.0 Mustangs | 22 | February 24th, 2010 04:28 AM |
| Australian Prime Minister John Howard has Balls | HMUSN | The Clubhouse | 9 | June 19th, 2008 04:29 PM |
| How Do I Prime An Oil Pump | armalpass96 | 5.0 Mustangs | 5 | March 18th, 2008 11:29 AM |
