351 W or C heads
I was wondering every summer I do a project to my 70 for next summer I was wondering about heads. I have heard alot of stuff about people putting 351 C/W heads on a 302 block to increase the hp.
I just wanted to know which model heads swap out the best and what sort of work is needed in doing this. I am young but know all of old motor heads in the area well who would be more than capible to do any work I could not do myself. I would just like to get a heads up on what kind of project I am going to get my self into. 1970 fast fastback with 302 and a C5
![]() You know its all about the gurth these days... |
C4 my appologies the smaller of the auto trannies I have forgotten at the moment weather is 5 and 6 or 4 and 5. I should know I just put in an new b&m shifter in a few weeks ago. sorry
I am running a 351w myself. I would tell you to go out and find to a set of old 289 heads. The closed chambered ones, have a value job done and put some chevy 202 values in them. They will give you nice compression.
Edit: Also remember if you change your heads, you will probly have to get a new intake.
GT40P heads from a 97 1/2 and newer Explorer.
those will all fit well on a 302 block?
#6 | |
Would using a newer head on an older motor create any problems?
I heard the P's need special header because of the placement of the the spark plug.
Threads Similar to: 351 W or C heads
| GT 40 X Heads. Need Help Deciding On These Heads, Or AFR`s | BillR1970 | Parts | 8 | May 12th, 2009 10:01 PM |
| GT40 heads vs GTP heads | 99TurboV6Stang | 5.0 Mustangs | 9 | September 18th, 2007 10:34 PM |
| RHS heads , are they good cylinder heads? | hitorx | 5.0 Mustangs | 25 | May 12th, 2007 10:55 PM |
| 289 Heads | ezra27 | General Tech | 0 | December 31st, 2006 12:09 AM |
| Boss 302 Heads Same As Cleveland Heads? | ken5_0 | Classic Mustangs | 8 | September 25th, 2006 04:18 PM |
