ka ching
Old April 16th, 2011, 08:06 PM   #1
1966 coupe
o's stang is on a distinguished road
ka ching
Hello all.
I just got my taxes back and money is going to my project 66. I need to do a disc brake conversion and i need spindles. I alo would like to do the suspension. I am dropping a 5.0 from an 89 mustang. Does anyone recommend any certain kits??????
Old April 17th, 2011, 12:13 AM   #2
Gregski is on a distinguished road
for the 66 you use the same drum spindles for disc brakes so it's an easy conversion, all you need is the caliper mounting brackets - $50 bucks each, calipers - ?, rotors - $85 bucks each, rotor splash shield - $40 bucks each, proportioning valve - $60 bucks, master cylinder - ? going the catalog route, or you can even try your local parts store for the consumables, rotors, pads, hoses, etc.
Old April 17th, 2011, 12:14 AM   #3
Are you going to keep the EFI or are you going to run a carb on it?
Old April 17th, 2011, 11:03 AM   #4
1966 coupe
Originally Posted by Gregski View Post
for the 66 you use the same drum spindles for disc brakes so it's an easy conversion, all you need is the caliper mounting brackets.
Even if it's a 6 cylinder I can use the same spindles?
Old April 17th, 2011, 11:07 AM   #5
1966 coupe
I am going to keep it EFI! you got a wiring harness for sale?
Old April 17th, 2011, 09:10 PM   #6
BA Mustang's Avatar
2001 GT
BA Mustang will become famous soon enoughBA Mustang will become famous soon enough
No, only if it was a 67+ car. You will need V8 spindles, suspension, and steering components.
Threads Similar to: ka ching
Kuh ching! dr.gonzo! The Clubhouse 5 March 25th, 2010 10:10 AM
Ching Chang Chong Redux The Clubhouse 1 July 10th, 2009 03:57 PM
Cha Ching psycho bob 2005 - 2010 5 December 16th, 2008 11:37 PM
