5.0 HO swap out
Old May 5th, 2011, 09:29 PM   #1
Look Ma! My First Post!
1965 Mustang Coupe
RidaPony is on a distinguished road
5.0 HO swap out
Hell all,
I just became a new owner of a decent '65 coupe. She has a 302 w/ a couple bolt ons. I want to do an EFI swapout so I have a slew of questions. Please help.
1. Where and what year can I get a 5.0 HO?
2. What kind of things should I be on the look out for?
3. How do I do the conversion?
4. How much should it run me?
5. What size rearend and what gears?
... and off subject... I'm about to start tearing into her this weekend. I'm going to put here in the air and really start inspecting. My first plan of attack in my restmod is to pull the engine/tranny. I want to clean and paint the engine bay and undercarriage. I'm a mechanic, but an acft mech in the USAF. I'm mechanically inclined, but I've never worked on cars. What basic tools should I get to to clean and paint the bay and underbody? And what cleaners, solvents, degreasers, paints, primers should I use?
Sorry for the long write up and I've done a sh*t ton of research, but I just need some help here. Thanks!!!
Old May 5th, 2011, 10:12 PM   #2
1965 Mustang Coupe
ajzride is on a distinguished road
Send a message via AIM to ajzride
BDK just did a great thread on the engine compartment, check it out!
Make your engine compartment look like new
Welcome to MM
Old May 6th, 2011, 01:39 AM   #3
Gregski is on a distinguished road
Hey bud welcome, first order of business you are tackling lots of separate things here, I can sense your excitement, which is cool, but my first recommendation would be for you to break up your questions into separate threads. Stick to the 5.0 swap in this thread, and if need be create new ones for the other topics, ie paint and prep, and another for the rear end. There have been tons of threads done on the 5.0 swap so run some searches first.
What should you be on a lookout for, well:
There were two Electronic Fuel Injection types for the 302 the early speed-density based EFI systems were fitted on all engines through 1988 after which year it was replaced by a mass-air type measuring system. Stay away from the speed density donor cars, so look for something 1989 and up.
Try to get all of your EFI parts from the same car, it may be cheaper to buy a used donor car than it is to piece meal all the parts. You will want the wiring harnesses to mate, you will want the computer to match the tranny, the size of your fuel injectors, the sensor types, etc. You can get a salvaged title car for cheap, etc. Stay away from cash for clunkers as their engines were seized.
Getting the right computer ECM what ever you call it is key. A9L is the most common 89-93 MAF 5-speed computer catch code.
1) E9ZF-12A650-AA (sometimes A2A), A9L, 89-92 Manual transmission Mustang.
2) E9ZF-12A650-BA (sometimes ), Manual transmission convertible
3) E9ZF-12A650-CA (sometimes C2A), A9P, 89-92 Auto trans Mustang.
4) F3ZF-12A650-AA Manual transmission:
5) F3ZF-12A650-BA Automatic transimission
6) F3ZF-12A650-DA (later replaced by DB), A3M1, 1993 Manual trans Mustang. Universal?
7) F3ZF-12A650-FA (later replaced by FB), C3W1, 1993 Auto trans Mustang.
8) F3ZF-12A650-CA, X3Z. 1993 Cobra
You will need an electronic fuel pump and an additional fuel line, this is the return fuel line that caries excess gasoline back to the gas tank.
List of EFI donor cars, not all of these are HOs
1986 – 1993 Ford Mustang
1987 – 1993 Ford Thunderbird
1987 – 1993 Mercury Cougar
1986 – 1992 Lincoln MK VII
1986 Mercury Capri
Note: I have not done this myself but I have acquired most of the parts and am fixin' on doing it also.
Old May 6th, 2011, 01:59 PM   #4
1966 coupe
o's stang is on a distinguished road
5.0 HO engines 87-1993 are your best bet. When you pull the motor it will be easier to take the wiring harness and ECU. You can also use that drive shaft. The rear end for those year mustangs were a stock 8.8.
And yeah i would look at that Make your engine compartment look like new article. It is really good and cheap way to do it. I am gonna the same thing.
Old May 7th, 2011, 07:43 PM   #5
65 Fastback
JamesW is on a distinguished road
check out my website...there is some info on the swap
JamesW's Website
Old May 7th, 2011, 08:24 PM   #6
SStang67 is on a distinguished road
A friend of mine did it and it ended up costing him over $1k when he already had a doner car. Had to get wiring harness adapters, cross members, fuel pump, and all kind of other unforseen stuff. He said if he did again he would have ditched the EFI and stayed with carb and saved about $700. I'm thinking of late 80s 302HO/AOD and going with carb in a 67. Good luck either way.
Old May 7th, 2011, 10:18 PM   #7
BA Mustang's Avatar
2001 GT
BA Mustang will become famous soon enoughBA Mustang will become famous soon enough
I stayed carb and I am still over 1k.
Threads Similar to: 5.0 HO swap out
Which one is easier??a rear end swap or engine swap? Bies08 V6 Mustangs 42 May 11th, 2010 04:33 PM
PI SWAP or ENGINE SWAP JK7208 96-98 4 March 19th, 2010 04:10 PM
PI Head Swap and Transmission Swap jEEd 96-98 18 May 14th, 2009 12:57 AM
1995 351 to swap or not to swap.& how to? Jeffery9508 94-95 9 August 3rd, 2008 08:00 AM
Can't decide, engine swap or PI swap? A few questions... k3vin 96-98 24 September 5th, 2007 06:48 PM
