DIY Floorpan replacement Step by Step!
Old May 23rd, 2011, 10:21 PM   #1
65 coupe W/ 88 5.0 5spd
Frankenstank is on a distinguished road
Post
This is my floor pan replacement on my 65 coupe. When I started doing this I found some instructions but they were not very detailed and I made some mistakes, so I took what I learned on the driver side and applied that to the passenger side which turned out 100% better.
So I hope this helps anyone else looking to do this and good luck to anyone else who does this on their car.
Items needed
Rusty floor pans that need replaced
new floor pans
cut off wheel
grinder
welder (I used a MIG)
welding gloves
welding hood
hammer
screws
drill
drill bits
primer
wire wheel
Safety Glasses
time
The most important A wife to do some welding
Originally Posted by Vince's98 View Post
From scum to Annoying.....
thats like wishing someone a horrible death, to wishing they get bit by a mosquito.
Originally Posted by 08blkgt500 View Post
trust me i had been pulled over once and he stated "ARE YOU FUCKING DEAF?!
Old May 23rd, 2011, 10:22 PM   #2
Post
The reason why we are even here the rusty floor pan must be replaced if not now it will only be a matter of time.
Make life easier on yourself by getting the vacuum and clean up all the loose material. Use a shop vac so the wife doesnt get mad cause you used her Dyson. lol
After initial cleanup there will be sealant/sound suppression material
Old May 23rd, 2011, 10:23 PM   #3
This must all be removed to make welding easier.
After you get that cleaned up you will find spot welds located on seat riser they must all be drilled out
After they are drilled out you can then pry the riser out.
And find the hidden treasures left behind
Old May 23rd, 2011, 10:24 PM   #4
Get that mess cleaned up again you will be glad that you did.
No you can fit the new floor pan in to find out where to cut.
I traced around it with soap stone.
Here you can see the outline of the new floor pan you cut about 2 inches inside the line.
But don't start cutting just yet.
Crawl under there are more spot welds waiting for you on the frame rails drill them out as well
Old May 23rd, 2011, 10:25 PM   #5
After you drill them out use the holes as guidelines for cutting it out (DO NOT CUT THROUGH THE FRAME RAIL) or you will be replacing it to.
Now start pealing up the part over the frame rail it will need to be removed.
Finish getting the rest of the rust out of there.
Be careful the frame rails are connected.
I think Fred Flin-stone would be proud to drive the coupe
Fit the floor pan in.
Old May 23rd, 2011, 10:26 PM   #6
Post
Fasten it with self tapping screws or clecos if you have them. (I messed this step up on the driver side and had to weld some huge gaps) well the wife welded them lol.
Weld around in spots so you do not warp the metal bounce around.
Eventually you will be welded all the way around.
After getting welded you can remove the screws that you were careful not to weld in (happened on the driver side to)
Weld in the holes (no pic for that one sorry)
Then grind down the welds how much is up to you.
Weld the frame rail to the bottom of the floor pan.
(pic from the top side where frame rail runs)
Old May 23rd, 2011, 10:28 PM   #7
Thumbs down
After getting it ground down coat the whole pan in primer 3-4 coats
You dot want to repeat this trust me.
Place the seat riser in get it lined up where you want it.
It will have gaps bang them as close to the body as possible to make welding easier
Clean up around the riser to prep for welding (no pic sorry)
just like before bounce around on the welding so you do not warp the metal.
Till you have finished welding
Like before grind the welds
Finally throw down a few coats of primer so you will not have to repeat the process.
I hope this helps someone out and I clearly explained the steps.
Old May 24th, 2011, 12:14 AM   #8
Israel is on a distinguished road
good read
Old May 24th, 2011, 12:17 AM   #9
Countryboy_99's Avatar
'95 GT
Was probably faster before I got it.
Countryboy_99 is on a distinguished road
yes, nice chronicling of a floor pan replacement.
Its red, long, and comes with an 8 foot bed attached. Wanna come play with it?
Old May 27th, 2011, 01:46 AM   #10
Gregski is on a distinguished road
excellent write up and pics, we hear your wife can weld but is she willing to travel - LOL, jk
Old May 27th, 2011, 02:04 PM   #11
chris66dad's Avatar
chris66dad is on a distinguished road
Great how to write up!
Well done and I am sure it will help many others who are looking for information
http://chris66dad.tripod.com/
Father Son Restoration
A code 66 coupe
289 4v, Roller Rockers, Electric fan
Performer & 650 Edelbrock
MSD ignition
Tri Y into 2.25 Shelby side exhaust
T5 conversion and 3.55 Trac Lok
Hydraulic clutch
CSRP Discs
Old May 28th, 2011, 03:40 PM   #12
I don't se why not.
Let's see
will need
airfair
rental hertz mustang will do
room and board
fine dining every night
2 masages at a spa(you get sore hunched over welding all day
then we can talk about her hourly rate
you still interested in her services
Old May 28th, 2011, 11:48 PM   #13
'95 GT
Yes.
Old May 31st, 2011, 12:18 AM   #14
Originally Posted by Countryboy_99 View Post
Yes.
I'm sure he meant welding services you pervert, welding !!!
Old June 1st, 2011, 01:02 AM   #15
1966 coupe
o's stang is on a distinguished road
this is a great article.
Old June 2nd, 2011, 12:42 AM   #16
'95 GT
Well so did I. I'm a terrible welder.
Threads Similar to: DIY Floorpan replacement Step by Step!
Step by Step guide to installing a Mark VIII motor in a 96+ GT. JC316 96-98 53 May 2nd, 2012 10:14 PM
Anyone have a good step by step on putting togather a mod motor? jrfan4life 99-04 25 December 14th, 2010 08:59 PM
Step By Step Sound System Installation 00-04 Mustang GT mixedbreed02gt Audio/Video 5 July 26th, 2010 09:00 AM
Shifter install step by step? killermach1 2005 - 2010 6 June 30th, 2008 10:38 AM
V6 - Bolt On's - Step By Step? CyberPrey V6 Mustangs 5 October 30th, 2006 11:39 AM
