Demon carb issues?
Old June 4th, 2011, 10:07 AM   #1
need4steed's Avatar
need4steed is on a distinguished road
Demon carb issues?
Hey guys, i have a 67 mustang that has a modded 347 motor in it. I have a demon 750 cfm carb on it and have been having some issues with it.
When I try to start it after sitting for a few days it will not start without some starting fluid shot into it. The electronic choak works as it should from what i can see. It closes and opens slowly when it gets warm.
Next, at 2500- 3500 RPM's (doesnt matter the gear) there is a slight miss. You can feel it and hear it. Nothing crazy, but just enought to feel and know somehting isnt right. When i get on it hard it misses just a bit and then takes off. Same thing happens when i get on it hard from a stop, shift at 6500 rmps, go into 2nd and there is a bad hesitation and then it takes off.
Last, when i am high into the RPM's and let off the gas, it backfires like a bunch of gun shots...normal?
Thanks for the help guys. Should i just get a holley carb instead?
67 Mustang = 492 HP/478 TQ
07 Mustang GT = JLT CIA with SCT Tune, Drops
95 MarkVIII= Project/ resurrection
Old June 4th, 2011, 10:25 AM   #2
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
I've never had any luck getting a Demon to work. You could always call tech........oh wait
It's hard to connect all those issues to one problem. It sounds like it may be lean if it's popping up high, and if it's hesitating when you stand on it, it may need more accelerator pump shot.
If you're going to buy a new carb, and you have a modded engine, I highly suggest giving Pro-Systems a call. You'll get a custom built Holley HP for about the same price as an OTB one. On top of that, you get the best customer service in the business. Pat can help you tune anything over the phone, but his stuff is usually spot on out of the box.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old June 4th, 2011, 11:32 AM   #3
1967 Coupe
20 @ 80mph?
mrtleavitt is on a distinguished road
Send a message via ICQ to mrtleavitt
Sounds a lot like a vacuum leak somewhere. Make sure all lines are hooked up correctly without any leaks and that any capped off ports have a good cap on them. Could also be a gasket that is sucking in air. I have gone through a bunch of carbs on my 428 FE. I started with a holley street avenger and that sucked. Then went to an edelbrock...huge mistake. Finally ended with a Holley HP and it is so sweet! I was able to fine tune it and it runs amazingly! It helps give me 450 hp with 12 mpg on the freeway (pretty amazing for a FE engine that is driven hard!) It's been 2 years now with no problems at all. The HP Holleys don't have a choke on them so it's fine here in Las Vegas but any cold weather and you might not want it.
Old June 12th, 2011, 09:42 AM   #4
need4steed's Avatar
Thanks for the help guys. When I get back home I will check everything again and make sure all things are plugged and sealed.
Old July 11th, 2011, 06:50 PM   #5
ultrafast is on a distinguished road
The motor sounds lean. Fatten up the low speed and see if it cleans up.Maybe even a little more timing. I have a mighty demon and overcame a hesitation. Unfortunately Barry Grant is no more. I am sure parts availability will go away. Mine starts immediately with no choke horn at all. Accellerates like a rocket. 427 windsor - 580 horse 540 tq. Oh yeah and check for vacuum leaks like mentioned before. Could be the whole problem!!
Threads Similar to: Demon carb issues?
MSD or Demon Coil sctravis77 Modular Mustangs 2 June 4th, 2009 11:44 AM
carb issues viperlocc 5.0 Mustangs 3 April 3rd, 2009 07:34 PM
DEMON Carb leakin fuel HELP MStang79 5.0 Mustangs 12 December 16th, 2008 10:33 PM
Carb issues maybe HELP 85slepr General Tech 12 June 20th, 2006 03:08 AM
