Brake Lights Issue
ok so here's the original problem:
Hey guys, its been a while since i've been active on the site. I have to revisit because i need some opinions on how to fix my brake lights. (I finally go my license yesterday and i was going to drive to school today however something is wrong with the brake lights.) My dad and i have been practicing driving(its a 3 speed manual) and during our practice drives we are pretty sure that the brake lights were working. However now they're not. My dad thought looking at the fuse box might solve the problem. And yea a couple of fuses were missing but not the ones that affect the brakes. When we bought the car, the guy we bought it from metioned some electrical work had been done but we didnt think to check it over too much. Now we think that who ever did the electerical work did a shoty job. And we're not sure what to do. We already changed the bulbs so we know thats not the problem. Also my blinkers and lights work. So its just the brake lights that are the problem. And here's the original solution: As many of you guys know i had some issues with my brake lights and it turns out that the brake switch and the spring kept touching everytime i hit the brakes. This caused it to brake the circuit. So to keep the two from hitting i just wrapped the spring in electrical tape and the problem is solved. (BTW the spring was used to help the brake pedal some back up. i tried taking it off but the pedal just stayed down.) And now the new problem: At first the brake pedal started not comming back up when i parked. ie. when i pressed the brake pedal when i was driving it would come back up, but when i parked the pedal stayed down. So of course the brake lights stayed on. Then even when i pulled the brake pedal bake up the brakes stayed on. Even when i'm driving they stayed on no matter what. Then after about 15 mins the fuse burns out. At first my dad and i thought it was the turn signal switch that needed to be replaced because we just bought a new brake switch a few months back. We went to Mustang Country to buy a new one and the guy said that it probably is the brake switch. My dad and i havent had a chance to get out there and test the brake switch yet but i just wanted to see what some of you guys opinions were. Thanks for the help in advance. |
'95 GT
Was probably faster before I got it.
I would get a light tester (not sure on the technical name, but its the screwdriver/all like thing that has a light in it and a wire coming out of the end) and use it to test the switch, and then check all your grounds to make sure they're grounding completely and have good connections. Check your wiring to make sure there are no frays, bad connections, or anything that would cause them not to ground when they're supposed to or be grounded at all times.
Its red, long, and comes with an 8 foot bed attached. Wanna come play with it? ![]()
Lost in the 60's
1968 GT 500 Super Snake
12.6 @ 114.3
I would check the the brake light switch with a test light.
There will be power on one side all the time. Then press the pedal and be power on both sides. |
definitely sounds like a break switch. If it was wiring, your breaks would not come on and/or would blow the fuse the instant you touched the break pedal. As for the pedal not traveling correctly, I would really consider having a mechanic take a look. Starting is optional, stopping is mandatory... Just my .02c but I would rather be able to choose to push the pedal and have my breaks work than have to choose which car to slam into to stop.
Threads Similar to: Brake Lights Issue
| Issue with fog lights | Unavailable | V6 Mustangs | 5 | January 3rd, 2011 10:35 PM |
| Possible Brake Issue | 2VSouth | 99-04 | 6 | November 30th, 2010 06:55 PM |
| Break Lights Out - ISSUE | WhiteLies | 94-95 | 0 | July 26th, 2010 05:52 PM |
| hazard lights issue | supermachone | V6 Mustangs | 2 | January 11th, 2008 05:28 PM |
| Brake Issue | 00redgt | 99-04 | 17 | December 4th, 2007 10:42 AM |
