Starting Problem
Old June 28th, 2011, 10:54 PM   #1
Bobby68 is on a distinguished road
Starting Problem
alright so i got my distributor and connected everything, electrical works lights go on wipers etc, now heres the problem i turned the key and VOILA! nothing not even a crank of the engine.... just silence. Any suggestions of what might be wrong?
Old June 28th, 2011, 11:21 PM   #2
1965 Mustang Coupe
ajzride is on a distinguished road
Send a message via AIM to ajzride
If you have silence I'm assuming you're not hearing the starter roll the motor? In that case, check the solenoid, it should be on the firewall somewhere close to the battery. It is a little black box with 4 posts on it:
The battery goes into the left-most, the starter comes off the right most, and the ignition switch start position goes into the middle left. You can always test the solenoid by disconnecting the starter, putting a jumper wire between the two left posts (where the battery and ignition switch go) and checking the starter side for 12V with a multi-meter. If you have 12V there, then remove the jumper and have someone hold the key while you check for 12V, if you don't have it there then there is a problem with your ignition switch, or the wiring in between. If you do have 12V, then check the wire going to the starter, make sure it is connected cleanly on the right post. If it is connected properly, then take the starter up to the parts store and have them test it.
If you already knew all of that, then sorry to insult your intelligence.
Old June 28th, 2011, 11:34 PM   #3
its all good man im pretty much starting out so im open to any type of advice ill come back later to see what happens thanks
Old June 29th, 2011, 11:08 PM   #4
Ok so a little update, i realized the starter wasnt connected <<<<good one right? so i went out connected the battery and not even the lights work theres no spark in the battery either... maybe the solenoid is gone im thinking? i put the screw driver on the solenoid and also got nothing. Sorry for the rookie questions im new at this just starting out my project for my dream car
Old June 29th, 2011, 11:37 PM   #5
1965 Mustang Coupe
I'm confused. Yesterday your lights and wipers worked. Today you hooked the starter up to the solenoid and now nothing works?
Old June 30th, 2011, 04:25 AM   #6
Yea i thought that was strange.... battery wont spark or anything, attached the neg and positive wires to a battery charger and also nothing worked im stumped...
Old June 30th, 2011, 08:52 AM   #7
1965 Mustang Coupe
The solenoid needs to ground to the fender well, make sure it has a good connection. Also make sure the started is grounded against the bell housing good.
Old June 30th, 2011, 08:48 PM   #8
SStang67 is on a distinguished road
you might have fried a fuse or two in the process. check that for lights and stuff. No crank would be solenoid or starter or ignition problem.
Old July 5th, 2011, 02:35 AM   #9
alright a little update, not the solenoid damn it, i checked the fuses they look ok but im going to take them out and check them thoroughly tomorrow just to make sure and ill get back to you guys on that. thanks for the help and keep the advice coming really appreciate it
Old July 5th, 2011, 09:53 PM   #10
alright, if i forgot to mention also when i connect the negative and positive wires to the battery terminals they dont give a spark like they usually do they do nothing actually, battery isnt dead i know that because i charged it, maybe something isnt grounding right?
Old July 5th, 2011, 11:41 PM   #11
1965 Mustang Coupe
Do you have a multimeter? If so:
Set it to DC Volts:
- check the positive to Negative
-- < 11.5V Bad battery
- check positive to block
-- < 11.5V bad ground
Set to tone
-- tone = grounded out on block
- check positive to chassis
-- tone = grounded out on chassis
Old July 6th, 2011, 11:47 AM   #12
Traction...?
1996 GT's Avatar
1996 GT/ 2008 GT Vert
1996 GT has a spectacular aura about1996 GT has a spectacular aura about
^ i had that issue. Or check your ignition switch, had that issue too. Can you get it to turn over from jumping the solenoid?
Old July 7th, 2011, 06:50 PM   #13
Alright guys i figured out what it was, and indeed it was the solenoid, that duralast crap dont last even a month lol. i went got myself a new one and now she cranks up and breathing. thanks a lot guys for your advice
Old July 7th, 2011, 09:01 PM   #14
1965 Mustang Coupe
I don't know about others experiences, but I don't find it un-common to fry one while you are trying to get things worked out and started for the first time. Once the motor is all lined out and starts up easily, they tend to last a lot longer.
Old July 9th, 2011, 07:26 PM   #15
alright so the engine cranks and everything, but it isnt cranking with the actual ignition, mostly everything is hooked up neutral safety switch is connected but theres one green wire sticking out from the firewall which has nothing attached to it and im pretty sure thats why its not working with the actual ignition, anyone know what that is?
Threads Similar to: Starting Problem
I Got A Starting Problem american_muscle 99-04 9 September 19th, 2010 07:14 PM
Starting problem Chris951 5.0 Mustangs 26 March 29th, 2009 04:19 PM
starting problem 99spaded 99-04 21 October 7th, 2008 05:23 PM
problem starting mustangman0001 5.0 Mustangs 3 March 4th, 2007 01:52 PM
starting problem Random-Hero V6 Mustangs 3 January 26th, 2007 10:10 PM
