Suggestions for modding my 64.5 Stang
Old July 1st, 2011, 12:03 PM   #1
Look Ma! My First Post!
1964 1/2 Mustang
Kalikus is on a distinguished road
Send a message via AIM to Kalikus Send a message via MSN to Kalikus Send a message via Yahoo to Kalikus Send a message via Skype™ to Kalikus
Aloha!
I LOVE the look of the classic Stang but the sound of the newer stangs and I was wondering what people thought would be a good modern Stang engine I could drop in my 64.5 stang. I also would need a newer, tighter suspension to throw on there with the engine for better performance. Any thoughts or suggestions? Also, want it to be a manual, but my current stang is an automatic, so i was hoping to change out the tranny as well, that shouldn't be a limiter on my engine choice I think as I can modify the undercarriage to the new tranny. Hopefully someone's got some great ideas out there. This is the first place I've looked, so any insight or pointers, suggestions, or links would be greatly appreciated. Mahalo!
John Ellis
Old July 1st, 2011, 07:03 PM   #2
1965 Mustang Coupe
ajzride is on a distinguished road
Send a message via AIM to ajzride
Budget?
A TCI front end will give you the suspension you are looking for, and eliminate the shock towers, making room for a variety of engine choices, including the new 5.0 coyote.
Talk to MustangOne about a TCI setup.
Old July 3rd, 2011, 11:00 PM   #3
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
Welcome to MM Forums...
This question is asked all the time.
This is the set up I am using in my new 1969 Fastback trans-am styled road racer
I install this in everything I restore now.
For me there is only one way to go here. It is not as hard as you would think. But the change to the old Mustangs ride and handling is so dramatic you will think you are driving a new Stang! With all the stuff is comes with is a savings over just buying rack & pinion, Disc brakes,front suspension, & Coil over shocks.
The kit comes with:
-Frame reinforcing plates
- Steel inner fender panels
-Jig welded crossmember
-Upper a-arm and shock mounting tower
-Urethane bushed upper and lower tubular a-arms
-Kick ass Urethane bushed Motor mounts for a 289,302,351 or 4.6 & 5.4 Mod motor
-Total Cost Involved Custom IFS dropped spindles
- Bolt-on steering arms for correct turning radius and ackerman
-Standard Power rack & pinion
-TCI All American coilover shocks with adjustable spring tension and black powder coated springs
-Eleven inch vented smooth rotors
-Detailed instuctions showing how to remove old suspension and install the new TCI unit
Here is a few I have done ... All TCI front ends
We are a dealer also, We Love TCI !!!
These all have 17" wheel and clear just fine. They have adjustable coil overs so you can set the hight you like.
Just look at all the room it gives you....
Threads Similar to: Suggestions for modding my 64.5 Stang
V6 Modding need a lot of advice/suggestions SON1C V6 Mustangs 64 July 14th, 2010 03:46 AM
Stang down suggestions on ts please DanishStallion 99-04 11 May 17th, 2009 02:30 PM
help with modding a V6 stang, uconnV6 V6 Mustangs 135 June 1st, 2008 10:37 AM
V6 stang, where to began modding? futureMACH1racer V6 Mustangs 31 April 24th, 2008 10:16 PM
modding suggestions supermachone V6 Mustangs 6 January 20th, 2008 03:27 PM
