2007 shelby gt
12.8 @ 107
engine claking
well i ran open headers for 3 days didnt drive it very much but maybe 50 miles in the whole 3 days i put mufflers back on it and now its making a claking noise in the engine like a vavle spring or valve has been displaced and needs to be reset and its not an xhaust leak
by the way its on my 1965
Video? That is not much to go on.
2007 shelby gt
12.8 @ 107
IT WONT LET ME but its right above the headers like under valve cover so it leaves to me to believe that i need to reset the valve with the recalibration tool because i ran open headers so it is somthing with the valves but just one side which is the passenger side closeset to the cabin toward the back of the engine just need to make sure what this noise is and dont wanna mess it up from driving it while its doing this
I'm kind of a noob around here, but I've never heard of resetting a valve. You can set valve lash by adjusting the rockers if you have stud mount rockers. Which you need to do after the engine has run for a few hours anyway. As long as you have headers and not just exhaust manifolds, you shouldn't have damaged anything by running with open headers. It is also possible that the noise has been there all along, and you just couldn't hear it over the noise of the open headers.
You can use a large screwdriver to find the exact spot of the noise. Put the handle to your hear, and touch the tip to the motor, it will act like a stethoscope. You can also buy an engine stethoscope (harbor freight) sells them. The best way to get a video on here is to upload it to youtube and link it. |
sounds like a rocker arm came off or broke.pull the cover and take a look.
#6 | |
This is what happened to mine. It was really hard to see with the rockers covered in oil. Spray them with some brake cleaner so you can get a good look at them. You are looking for something like this:
2007 shelby gt
12.8 @ 107
thanks so much i pulled the valve cover off and the rocker arm had come loose and ws making the claking thanks so much guys
Threads Similar to: engine claking
| claking engine | rickrubin2 | Classic Mustangs | 3 | July 12th, 2011 08:22 AM |
| 2005 V6 engine swap to 2002 saleen engine | MCLARK | V6 Mustangs | 7 | May 14th, 2010 06:02 PM |
| 2005 V6 engine swap to 2002 saleen engine help? | MCLARK | 2005 - 2010 | 7 | January 11th, 2010 09:27 AM |
| Engine install: Life engine up, or drop engine? | trill gear head | 2005 - 2010 | 14 | October 26th, 2009 01:17 AM |
| Will a 2002 Gt Engine Directly Replace a 2000GT engine? | Bigb2000GT | 99-04 | 7 | April 22nd, 2007 05:09 PM |
