1967 Mustang Coupe 289 2v
Need help deciding which setup for 67 mustang
ARP 154-3601 - ARP High Performance Series Cylinder Head Bolt Kits - Overview - SummitRacing.com
COMP Cams K31-238-3 - COMP Cams Xtreme Energy Cam and Lifter Kits - Overview - SummitRacing.com Crane Cams 11746-16 - Crane Energizer Roller Rocker Arm Sets - Overview - SummitRacing.com Summit Racing SUM-56250HSPS - Summit Racing® Bolt Kits - Overview - SummitRacing.com Trick Flow Specialties TFS-51400002 - Trick Flow® Twisted Wedge® 170 Cylinder Heads for Small Block Ford - Overview - SummitRacing.com Trick Flow Specialties TFS-51400419 - Trick Flow® Head Bolt Bushings - Overview - SummitRacing.com Weiand 8020 - Weiand Stealth Intake Manifolds - Overview - SummitRacing.com This setup I got it from someone in a forum, is a little cheaper than the edelbrock. Unless I'm missing something. Edelbrock 2091 - Edelbrock Power Package Top-End Kits - Overview - SummitRacing.com Edelbrock 77780 - Edelbrock Aluminum Roller Rockers - Overview - SummitRacing.com Edelbrock 9632 - Edelbrock Hardened Steel Pushrods - Overview - SummitRacing.com This is the Top End obviously, with roller rocker arms. Holley 550-400 - Holley Avenger EFI Engine Management Systems - Overview - SummitRacing.com EFI, Why not. But would it work in either setup? MagnaFlow 15816 - MagnaFlow Performance Exhaust Kits - Overview - SummitRacing.com Patriot Exhaust H-8426-1 - Patriot Full-Length Headers - Overview - SummitRacing.com Needed to upgrade from a 2.00 setup and stock manifold. Gear Vendors under/overdrive auxiliary transmissions Hot Rods, Ford 3-Speed Automatic Muscle Car/Street Rod/Restoration. Like the idea of just swapping it back like nothing was ever there and from where I come from swapping to an AOD or 4r70w was about the same. Just Rear Ends - Product Display I have open 2.79 enough said. Sorry I do need help in which ratio. Open to suggestions from 3.00 to 3.55 only. I got a week of vacation coming up in mid August, any input would be greatly appreciated. Thank you |
Thanks but let me give you a little background. Where I leave it seems that people are afraid to work in classics. Let me give you two examples: I went to a muffler shop to fix a leak at the collector he recommended me to a performance shop because he was afraid to do it. The performance shop quoted me 300+ to install headers. Ok, ha So didn't happen. Next I go to another shop where they have a real nice car like mine it belongs to the mechanic, I asked him if he would be able to change my rear gears and he said not really cause he did it to his ride but took him a while.
So yes I'm not too mechanical inclined but I can do work with supervision and by reading forums. So far I did the brakes and install the Pertronix and the tiny tach. So what's going to happen is that I'm going to drive 2 hours to my in-laws and procure the help of my brother-in-law and go that route. The reason I like the EFI and Gear vendors is because if it ever(unforeseen and unlikely reason, ) I have to get rid of the car, I could just replace them and keep them. Oh by the way I got a quote from a shop in Houston(Performance Mustangs) 2000.00 to install an AOD and get credit for the C4. The only shop in town that all (3) auto parts recommended for transmission work has never heard of Gear Vendors. In summary that's why I looking into going the bolt on route. |
1967 Mustang Coupe 302 4V
I know a few shops that'll work on ol Stangs, but they're up here in Austin. There's even a 65-73 Mustang shop here. Are you just wanting someone to do the AOD & gears?
2001 GT
I have a set of Trick Flow head bolts that I don't need anymore.
Not anymore. I'm going to do it with the help of my brother in law. I'm going with the following setup: edelbrock kit 2091, Hedman headers, magnaflow exhaust, gear vendors unit and 3.25 third member. Oh and a b&m shift kit. Finally the Holley avenger tbi. Its all been bought just waiting for a couple of things. I'll post an update by the end of august.
1967 Coupe 289 2V C4 8" Rear. Only Mod so far Pertronix, Mini Tach and Front Disc Brakes. |
Threads Similar to: Need help deciding which setup for 67 mustang
| 05+ mustang exhuast setup vid | JoshC! | 2005 - 2010 | 2 | November 21st, 2009 08:41 PM |
| Mustang tubular setup | Speedstang302 | 5.0 Mustangs | 8 | October 1st, 2009 12:26 AM |
| setup for my stock 1986 mustang? | 1986shr0om | General Tech | 6 | April 28th, 2009 08:34 PM |
| whole setup for my 00 mustang | Santaniello3blkstang | V6 Mustangs | 28 | June 20th, 2007 01:25 AM |
