Fuel Octane Question
I have a 1973 Mustang Convertible and it starts and runs fairly well. I just bought the car and it needs some work, but it is a running project car. I put 93 Octane unleaded in the car and am concerned that I may need to to perform some modifications to run this fuel. Right now, the car hesitates when accelerated from a stop and also from low speeds, but I have not floored the engine. The exhaust is clear, but after driving on the highway for 30 minutes I noted some black soot on the rear bumper, so I think the engine is running rich. I plan on replacing the plugs and points, but I am not sure if I can use 93 octane unleaded. The engine is a 351 4V (4Barrel). I don't think the engine has been modified. Any tips would be greatly appreciated. Thanks
Sounds like you need a tune up and carburetor rebuild. 93 octane will be fine in that engine. You could probably get away with 89 octane.
also ck the dist. vacuum advance diapragm and make sure it's working correctly.
I think the octane grade is OK, but it sounds like you might re-jet your carb. What size jets and needles are you running now?
William 68 Coupe 289 C4 3:55's/Trac-Lok |
dont run higher octane if u dont need it. its highly possile that the engine is due for a rebuild, so the compression has lowered, causing the engine not to like that 93 octane fuel you're using. do a compression test.
TO: Ricers- 1) there's no replacement for displacement 2) my lug nuts require more torque than your engine makes 3) a light car doesn't excuse a weak engine 4) a bottle of pepsi has more liters than your car eating rice builds muscle |
I'd also say to give it an "Italian Tune-up"
You know, where you go out to the highway and get into it a little bit. Helps flush out residual gas and other junk from the intake planes before they turn into power robbers. I also agree, regardless, a tune up is most definatly in order. No matter what anyone tells me when I buy a car (except brand new ), the first thing I do is a tune up. Cleaning and rebuliding the carb is another plus.
Getting a new computer . . . . $1500 Restoring a 40 year old Mustang . . . . $50K~ Building a business . . . . $Don't go there. Being this damn broke . . . . Priceless! |
Threads Similar to: Fuel Octane Question
| Got a question about fuel | ocsailor86 | 96-98 | 3 | October 12th, 2007 12:10 AM |
| fuel pressure question? | 02ATIstang | 99-04 | 11 | May 23rd, 2007 12:51 PM |
| 93 octane fuel | jersey98gt | 96-98 | 12 | May 9th, 2007 01:38 PM |
| Fuel Question | arc590 | 5.0 Mustangs | 4 | May 2nd, 2007 11:04 PM |
| What Fuel Octane To Use? | Impackt | 5.0 Mustangs | 46 | March 20th, 2007 06:47 PM |
