head recommendations - Page 2
Old October 21st, 2011, 02:38 PM   #21
frdnut's Avatar
1968 sprint
11.82@120.85
frdnut is on a distinguished road
You have pedestal rockers..They are not adjustable..You simply torque them to the recommended torque and that should do it..If they are opening the valves (assuming you are on the base circle of the cam) then the pushrods are too long...You must either shim the pedestals or get shorter pushrods..
Old October 22nd, 2011, 03:56 PM   #22
I'm Hella From Nor*Cal
707Stang's Avatar
2008 GTI
14.65 @ 99.83
707Stang is a jewel in the rough707Stang is a jewel in the rough707Stang is a jewel in the rough
Originally Posted by ajzride View Post
DOH
lol! indeed!
that's what i ultimately ended up doing, shimming the pedestals. went to try to just crank it and see how it would sound and the sumbitch started instantly (no joke) bumped the cold start down now and i filled it back up with tranny fluid and finally took it out for a spin at night. all i can say is WOWOWOW what pull! but i have a cracked ceramic on #1 so i'll be replacing that one tonight and seeing how the idle and power level out.
The Curse 600 CFM Edelbrock, Hookers, Pertronix billet dizzy, Accel coil, GT40 heads, 5.0 h.o, dynomax exhaust, SSBC, FRPP 9mm wires, tci
Threads Similar to: head recommendations
Recommendations? Goliathjz V6 Mustangs 8 March 25th, 2011 11:41 PM
Head and Header (all bolt on also) recommendations please 1996StangGT 96-98 0 March 2nd, 2011 01:01 AM
After 6k DDM Tuning head and foglight HID's and smoked head and foglights. freefallin2000 99-04 20 February 20th, 2011 07:00 PM
Cam Recommendations? despinos505 2005 - 2010 23 June 17th, 2010 09:02 AM
Need recommendations on oil please 06saleen3v 2005 - 2010 12 October 21st, 2007 03:26 PM
