bogging issues in low rpms?
Old October 1st, 2011, 02:01 PM   #1
1967 mustang coupe
ma67cpe is on a distinguished road
Send a message via Yahoo to ma67cpe
I have a 67 mustang with a slightly modded 302. The motor has an autolite 4100 carb with a crower 15202 cam, edelebrock performer intake and its bored 40 over. I was having a problem with vacuum so (baron) moved my vacuum from the carb to a port on the intake. Now Im getting advance but when I put it "in time" it boggs in low nd runs great in high. If I advance the timing it runs great in low and pops,backfires exc in high. I havent tried retarding the timing to much cause I was afraid that the lows would get worse. any body have any ideas or free time this weekend? thanks in advance. Here are pictures of my plugs.
Old October 1st, 2011, 05:08 PM   #2
S-Car-Go's Avatar
68 Convertible, 331 T5
S-Car-Go is on a distinguished road
Get your timing sorted out. Start by disconnecting the vacuum advance and plugging the carb side. You don't need it at this point. V/A is for just mileage. Figure out where TDC is. Pull the valve cover over #1 and confirm both valves are closed when the balancer says TDC. Maybe the pointer is off. You will chase your tail until you get it timed right. Maybe the distributor is out 180* and your timing is so wacked it runs. I've seen this happen.
Old October 1st, 2011, 05:10 PM   #3
1967 mustang coupe
Ok I will start there. thanks for the advice.
Old October 4th, 2011, 06:09 PM   #4
1965 2+2 Mustang
RebelTide is on a distinguished road
Once you follow the TDC instructions given to you by "the snail" correctly, line your timing mark up for 9 degrees initial advance. This should be a good starting point for the cam you have. Whatever you do, get a new set of plugs. Street cars do well with the old BF42's. If you want to play dragracer, you can drop down to the BF32's. I don't know the current Autolite numbers for those plugs. My age is showing. Good luck.
Threads Similar to: bogging issues in low rpms?
still bogging jman214 99-04 3 September 2nd, 2011 12:50 AM
Bogging at low rpms. BlueGT01 99-04 6 July 27th, 2011 04:22 PM
Car Bogging when hot Ticket-Me-Yellow V6 Mustangs 1 April 9th, 2009 08:44 PM
Bogging Down At Wot, Please Help bengt87 5.0 Mustangs 6 August 21st, 2008 08:26 AM
Car Is Bogging Out 98 gt 96-98 5 November 12th, 2006 09:07 AM
