351W & M questions
Old October 20th, 2011, 03:54 PM   #1
Hellssorrow's Avatar
1967 Mustang Coupe
down hill count?
Hellssorrow is on a distinguished road
351W & M questions
I have found a ton of information while searching the internet, however I am cautious about what I read. I was given a 351W and told the mustang I bought has a 351 Modified. What is the difference between these engines? I want to turn one of them into an awesome daily driver and have plenty of power to burn the strip at the speedway every once in a while. How do I tell if they are original or aftermarket blocks? What is the most I could stroke it to? What is the best heads to slap on? What is be the idea manual transmission for this setup? What information or pictures would you need to help answer my questions? Thank you for taking the time to read this.
Old October 20th, 2011, 03:56 PM   #2
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
use the windsor
SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT
BAMA Performance Drag Team Member #4
Old October 20th, 2011, 04:08 PM   #3
1967 Mustang Coupe
down hill count?
I forgot, they appear to be 1969-1974 351's. I would like to convert the one I'll use to EFI. Any suggestions to that too? Details please.
Old October 21st, 2011, 11:23 AM   #4
1967 Mustang Coupe
down hill count?
My post seems to be like a plauge. What am I doing wrong? I only received one very brief answer to one question.
Old October 23rd, 2011, 02:13 AM   #5
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
Zatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud of
iTrader: 15 reviews
Moving this to the classic section where you should get more help.
Black Bullitt Rims FT/FS
Looking to Sell or Trade for Silver FR500s
Looking to buy a lot of 99-04 Interior Pieces
If you have any for sale, PM me
Old October 23rd, 2011, 01:31 PM   #6
1965 Mustang Coupe
ajzride is on a distinguished road
Send a message via AIM to ajzride
First, if your 67 mustang has 351m it is definitly not the stock engine (in fact any 351 in a 67 is not stock). 351m is a big block engine found mostly on trucks and vans. The 351w is a small block motor based off the same technology as the 289 and 302. In fact pretty much all performance parts except intake and distributors will fit all 3 motors. Given how much more stuff is available for the Windsor, you will probably find that it is going to be the easiest motor for you to work with.
Old October 23rd, 2011, 04:38 PM   #7
1967 Mustang Coupe
down hill count?
That's some good information to know. Thanks ajzride.
1967 mustang coupe with nothing special yet.
Old October 25th, 2011, 08:26 PM   #8
Gregski is on a distinguished road
"The most popular stroker for the 351W is the 393. Perfectly suited for a variety of uses from street to pure track excitement, the 393 is a great combination for any Ford car or truck. If having an easy-going high horsepower engine is something you would like to achieve, the 393 is perfect for you." I ripped that off from here, LOL
FordStrokers.com 331-347-408-418-427 Custom Built Small Block Ford Engines - Ford Stroker Kits :: Coast High Performance Rotating Assemblies :: 351 Windsor Stroker Kits
The 351cid V-8 was introduced in 1969, and was available with 250 or 290 hp. (from Wiki, lol)
Old October 25th, 2011, 09:56 PM   #9
1965 Mustang Coupe
Gregski lives!!! Glad to see you again man.
While The 393 is very popular, and I in fact considered it strongly for my build. My machinist highly recommend the 408 over the 393 due to the longer rod, which gives it a higher dwell time at TDC, which allows for higher compressions on lower octane fuels.
This is all based on verbal information from the machinist, I did not go through any effort to verify this.
Old November 7th, 2011, 03:34 PM   #10
frdnut's Avatar
1968 sprint
11.82@120.85
frdnut is on a distinguished road
The 408 is a very popular build because it fits into the block very easily with the right parts.My Scat rotating assembly went right in with only a little grinding on the oil pump and the block where the oil pump mounts...Getting back to the original question the 351M and 351W are very different engines..The M is basically a taller deck cleveland motor..The motor was an absolute dog in stock form but they do have great potential with aftermarket parts..The problem is they were never installed in mustangs so motor mounts and headers would be very tough and expensive to get..Most of them also have a big block bellhousing pattern which narrows your transmission selection as well....The windsor is by far the easier engine to build and install in your mustang...
Old November 7th, 2011, 03:50 PM   #11
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
351M is just a destroked 400, which is part of the Cleveland family (335-series). Cleveland heads interchange, and would be the first step towards building that motor if that's what you choose to do.
That being said, Windsor parts are much more prevalent, and there's a lot more knowledge out there on building one.
O o
/¯/______________________
\_\
Threads Similar to: 351W & M questions
more 351w top end questions viperlocc 5.0 Mustangs 10 November 21st, 2008 12:35 AM
351W questions viperlocc 5.0 Mustangs 6 October 28th, 2008 09:16 PM
351w questions laztug 5.0 Mustangs 6 July 18th, 2008 11:42 PM
351w questions fastlane_24 94-95 1 June 12th, 2007 11:50 PM
351w questions javier351lx 5.0 Mustangs 2 June 6th, 2007 12:52 PM
