Picking the correct radiator
Old October 21st, 2011, 11:14 PM   #1
545cubes is on a distinguished road
Hey Guys-
Need some advice. I have 67 Mustang Fastback and currently at the point I have to buy a radiator. I am making around 600hp to the wheels. BBF 460/545ci Need some suggestions on the recommended radiators for this set up, please. Thanks
Old October 22nd, 2011, 11:27 AM   #2
frdnut's Avatar
1968 sprint
11.82@120.85
frdnut is on a distinguished road
I would go with the biggest aluminium rad you can fit in the car..I am running a 19X26 universal fit northern rad and it fit into the car very easily using the stock big block style mounts.....For your application I would remove the battery tray(relocate to trunk) and move the voltage regulator so you could fit an even wider rad into your car.
Old October 23rd, 2011, 12:08 AM   #3
Thanks for your input. I see radiators that run anywhere from $200 - $800 and I cant figure out why the big difference in price. Seems that BeCool and Griffin are more expensive than the others. Are they thaty much better and is this a case of "you get what you pay for"?
Old November 4th, 2011, 10:13 AM   #4
1965 2+2 Mustang
RebelTide is on a distinguished road
I have used the alum. radiators from www.championcooling.com.Top quality & lower priced. Be sure to enlarge your rad suports opening to match a wider width 4 row unit.
Ebelbrock water pumps work well for us too. Use Prestone 50/50 pre-mix to fill it.
I also like Flex -O- Lite products. Good luck.
Threads Similar to: Picking the correct radiator
Correct Psi izze01 5.0 Mustangs 4 February 25th, 2008 10:41 PM
Is this correct? whitefox89 5.0 Mustangs 16 December 22nd, 2007 09:20 PM
Is this correct???? ma67cpe 99-04 4 September 5th, 2007 03:06 PM
is this correct??? 83five0 5.0 Mustangs 0 November 27th, 2006 10:48 PM
The correct ECM cobraetti General Tech 1 August 2nd, 2006 06:00 PM
