What all is needed to install a AOD transmission in to a 1966 Mustang
Old October 29th, 2011, 10:21 PM   #1
1966 mustang coupe
unknown
BFLOYD2447 is on a distinguished road
I got a AOD out of a 1988 LTD stationwagon I also got the engine I am not sure if its a 5.0L or the 5.8L can anyone help.
Old October 29th, 2011, 11:59 PM   #2
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
you will need the shifter and the linkages. I would grab the neutral safety switch wiring plug & drive shaft.
Old October 30th, 2011, 08:32 AM   #3
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
It will take a special set of headers as well. AODs are wide.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old October 30th, 2011, 08:36 AM   #4
1966 mustang coupe
unknown
What aboutg a cross member and trans mission mount, will I need to replace either from my cars factory equiped. It was a 3 speed manual.
Old October 30th, 2011, 08:51 AM   #5
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
I think you do, and a driveshaft too.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old October 30th, 2011, 10:35 AM   #6
1966 mustang coupe
unknown
What needs to be dome with the driveshaft, and is there a factory crossmember that can be used or do I have to go aftermarket? Thanks for all the help.
Old October 30th, 2011, 08:32 PM   #7
Lost in the 60's
MustangOne's Avatar
12.6 @ 114.3
You will need a crossmember, You need the drive shaft for the front yoke.
Take note of how the trowel linkage interacts with the AOD linkage.
Threads Similar to: What all is needed to install a AOD transmission in to a 1966 Mustang
1966 Stock Shifter and AOD Transmission Compatible? Fishrmn703 Classic Mustangs 3 November 22nd, 2010 10:54 PM
1966 Mustang GT 66mustang619 Classic Mustangs 29 June 10th, 2010 12:18 AM
1966 Mustang MARKb47 General Tech 0 March 5th, 2010 04:42 PM
1966 mustang question chocolate Classic Mustangs 5 October 6th, 2009 08:46 AM
1966 Mustang Hardtop? 1_Bad_X Classic Mustangs 11 November 11th, 2006 03:12 PM
