Shock tower notching
When notching shock towers for a BB has anyone run into problems with the fact that you're also cutting away the heavy support brace that is there also?
Thanks |
April 2010 ROTM
1967 Fastback
That support brace really isn't all that heavy to begin with. How far are you planning on notching the towers? As long as you use thick plate steel to replace what you cut out and have an experienced welder weld it in place, you will be good to go.
Still looking for the "Definitive" answer, many notchers have cut 2" - 2 1/2" in towards the spring.
#4 | |
Lost in the 60's
1968 GT 500 Super Snake
12.6 @ 114.3
You have to support what you remove.what are you trying to do? witch BB and what year of Mustang. Me I do it differently than what you are thinking of doing. |
67 460.
Thanks |
Lost in the 60's
12.6 @ 114.3
What are you going to do to hold your frame rails together?
Are you adding the torque box on the Passenger side? What sub frame conectors are you using? Are you going to use slicks? Notching the shock towers will make the motor fit, Im just wondering how you are going keep the rest of the body together. The 460 has a lot of torque. Torque is what takes the front & rear frames out. |
#7 | |
Pro Street with total tear down then your OK connection for blasting Not sure about holding the frame rails together, never seen this addressed New torques boxes Com Eng back half kit with their subframe conn No slicks, MT's Stock 460 9.6 comp with Edlebrock top end kit, 514 HP, 565 TQ |
Threads Similar to: Shock tower notching
| The difference with strut tower and shock tower braces on a convertible | 1SICK5.0VERT | 94-95 | 29 | September 5th, 2011 11:48 PM |
| Shock Tower | GP-SE | 99-04 | 2 | October 6th, 2010 09:51 AM |
| shock tower repair | stangzor | 5.0 Mustangs | 4 | August 8th, 2009 02:16 PM |
| Shock Tower Brace | 06GTMustang89 | 2005 - 2010 | 1 | November 12th, 2007 04:04 PM |
| Shock Tower Rust | terribleonexx88 | 5.0 Mustangs | 2 | November 2nd, 2006 10:06 PM |
