Turn Signal Light
Old June 3rd, 2007, 05:14 PM   #1
BoomerSixZero's Avatar
BoomerSixZero is on a distinguished road
Turn Signal Light
Hi,
I have a 1966 coupe.
All of a sudden, my passenger-side, front turn signal light doesn’t flash off and on and the turn signal indicator light in the instrument cluster doesn't flash either.
The passenger side rear light is fine, and all the lights on the driver side work fine.
The passenger-side, front turn signal light will turn on when I switch on my parking lights, but the light won’t flash. The turn signal indicator light in the instrument cluster won’t turn on at all.
I replaced the turn signal light bulb and the indicator light bulb but that didn't solve the problem.
Even though the two lights won't flash, I can hear the flasher switch clicking, which I guess means it is okay. Am I wrong?
I’m thinking the flasher switch will either work or it won’t work.
Could the flasher switch be the problem?
Old June 3rd, 2007, 06:54 PM   #2
Classic Moderator
Horseshoeing's Avatar
Horseshoeing is on a distinguished road
Could be. I think I would start there. Could be a bad ground. Get a volt meter and start testing every thing.
Classic Mustangs are the best! Get one.
Old June 9th, 2007, 12:22 AM   #3
Checking
I checked it out but have little patience for that kind of checking. I decided to take it to an auto electric shop to get it fixed. Next week the technician will fix my horn, too, which hasn't worked since I'd have the car (8 months).
Old June 9th, 2007, 12:39 AM   #4
1965 Mustang Fastback
nba1341 will become famous soon enough
oh so it was wiring in your steering column then?
I'm a good boy now.
[COLOR=red][B]slow car club - crew member 7 of 9
[COLOR=White]Mood: Cool :cool:
[/COLOR][/B] [/COLOR]
Old June 9th, 2007, 08:39 AM   #5
Classic Moderator
Tell us what it was.
Old June 9th, 2007, 11:11 AM   #6
Update
Often, I can't understand a technician's explanation of a fix. They explain fast and use terms I'm not very sure of. Anyway, he said there was a connection cluster of wires (or something like that) under the dash above where my left knee would be. There was a female connector that had worn out and created a bad connection. He didn't have the part to replace it, so he joined the male and female wires with tape and re-established a good connection.
Everything works (but I had to go back to him to get my steering wheel put back on straight).
That's what I could make out from what he said.
Does this make sense?
I go back to him next week to get the horn working. He said he needs to replace the horn kit, apparently inside the steering wheel column, and then "re-engineer" a broken/missing part on my steering wheel, I believe, to establish the connection and get things working the way they are supposed to. He gave me the option of putting in a new steering wheel, but the previous owner of my car had installed an "oversized" steering wheel that I'd like to keep using.
Old June 10th, 2007, 08:17 AM   #7
Classic Moderator
Makes sense to me.
Threads Similar to: Turn Signal Light
Turn signal help novamastr 5.0 Mustangs 16 January 26th, 2009 02:52 PM
brake light/turn signal probel jim.munoz V6 Mustangs 2 October 20th, 2007 05:18 PM
turn signal? thatonekidw/theGT Modular Mustangs 3 July 22nd, 2007 05:39 PM
Turn Signal CBSTANG 99-04 9 May 28th, 2007 11:38 AM
Turn Signal Light themav46 V6 Mustangs 4 September 30th, 2006 10:09 AM
