Help with T5 tranny swap into 1969 Mach1 351W
Old January 12th, 2012, 08:09 PM   #1
cfauvel is on a distinguished road
Help I just got my mustang back from my mechanic and am having some issues.
1) the pedal travel is not right. The mechanic said that when he tries to adjust the linkage to where the pedal is returning to its proper no-load height, that when you press down on the pedal it is pushing the clutch fork too much and getting the pressure plate's fingers touching the clutch plate.
so the pedal is real low to the floor and releases the clutch fairly close to the floor. I can use my foot to pull the pedal to its normal position, but that leaves several inches of travel before anything happens.
I am using a 93 T5 and bell housing. Using the fulcrum adapter made for this swap and bell housing to be able to maintain my original clutch linkage.
had to go to a smaller flywheel and clutch kit as the original one for the 351 was too wide. The original was 11" 164 tooth, the new one is 157 tooth and either 10.5 or 10" ...the parts used were for a 1968 289 (flywheel and clutch kit)
I would have thought the fulcrum adapter would have preserved the geometry so that the linkage wouldn't need adjustments.
Any thoughts?
Chris
Old January 13th, 2012, 09:30 AM   #2
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
Sounds like you are missing a spring.
Check to see if you have the big spring above the clutch pedal.
Then you have a second spring going from the clutch fork to the lh lower control arm.
The last spring is from the top of the z bar and goes to the bottom of the master cylinder. there is a tab that comes out and has a hole in it.
With all of the springs in place you can adjust the pedal to the height you like.
Old January 13th, 2012, 11:45 AM   #3
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Wouldn't he want the big spring above the pedal removed? I know when I put my Centerforce clutch in, the instructions said to remove it because it's an assist spring, and not a return spring. When I installed the clutch, that spring had the pedal pulled about halfway to the floor before I removed it, then it was great.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old January 13th, 2012, 06:08 PM   #4
Lost in the 60's
MustangOne's Avatar
12.6 @ 114.3
With that big spring it will bring the pedal back up to the full height away from the floor.
Old January 13th, 2012, 09:39 PM   #5
BA Mustang's Avatar
2001 GT
BA Mustang will become famous soon enoughBA Mustang will become famous soon enough
Mine does the same thing and I have the big spring
Old January 13th, 2012, 10:39 PM   #6
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Maybe we are talking about two different things. There is a big spring under the dash that pulls the pedal to the floor. It's an assist spring, and not a return spring because the old three finger pressure plates were very stiff, and the pedal was hard to push. If you have installed a modern diaphragm type pressure plate, you need to remove this spring, or it can actually partially disengage the clutch and burn it up. The new diaphragm clutches are much easier to push, and the spring is strong enough to overcome the pressure, and bring the pedal towards the floor,so if you remove the spring, the pedal will move farther away from the floor, and save your clutch.
Mustang Clutch Spring and Pedal
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old January 14th, 2012, 09:17 AM   #7
Lost in the 60's
MustangOne's Avatar
12.6 @ 114.3
yes you are correct. That makes it clear.
Old January 14th, 2012, 11:23 AM   #8
BA Mustang's Avatar
2001 GT
Ok cool, I'm going to have to do this sometime next week
Old January 14th, 2012, 11:26 AM   #9
Thanks for all the replies
ok , yes the 1968 289 clutch kit installed is a diaphram type rather than three finger type like my old 351w clutch kit.
1 - under the dash I have a big moma spring, which is green in color (the chassis manual states it should be brown for the 351w, but if it is an assister spring and not a return spring the green would be better than a brown) I gotta remove the pedal to get that spring off right?
2) at the bottom of the zbar there is a hole, which right now has a smallish spring going from this hole to the hole in the clutch fork, which appears to me to be holding the rod tight against the clutch fork.
3) at the top of the zbar, where the pedal's rod attaches to there is another hole where a spring COULD be attached, however, none is there right now and I don't see the tab on the firewall where this return spring would attach to.
Many years ago I removed a weird spring that sounds like it could be the return spring that someone mentioned connected to the lower control arm.
It's aout 16" long with 13.5" of straight rod and 2.5" of spring. The spring is pretty strong.
would anybody have a picture of the springs attached to the lower part of the zbar and where the little tab on the firewall is?
Chris
Old January 14th, 2012, 12:05 PM   #10
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
1: yes, that spring needs to be removed. I didn't take my pedal out, but it's a bear to do. The link I posted gives instructions.
2: yes
3: yes, there should be a spring there, and there should be a bracket on the firewall to attach it to. If my car were here, I'd take a pic, but it's getting the cage done right now.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Threads Similar to: Help with T5 tranny swap into 1969 Mach1 351W
most recomended tranny in a 1969 fastback? patrick1989 Classic Mustangs 9 May 27th, 2011 04:08 AM
351W 1969 Crank MustangMatt96GT 5.0 Mustangs 0 March 10th, 2010 06:10 PM
mach1 eaton swap? white03mach1 4V / SVT 15 February 27th, 2010 10:04 PM
mach1 eaton swap white03mach1 General Tech 4 January 16th, 2010 06:29 PM
Best racing tranny for 351w cams-shelbycobra07 5.0 Mustangs 3 July 22nd, 2007 01:52 AM
