Question regarding a 67 Fastback suspension and tranny change - Page 2
Old February 6th, 2012, 09:24 PM   #21
nce74 is on a distinguished road
Originally Posted by outlawz916 View Post
i would get sub frame connectors, 620 coils, new bushings in your leaf springs, new shocks, export brace, monte carlo bar, and thick sway bars and see if that makes it ride like you want it to
Thanks for the info. Do you know of a place where I can get a quote for these items that has reasonable prices?
Old February 7th, 2012, 10:56 AM   #22
frdnut's Avatar
1968 sprint
11.82@120.85
frdnut is on a distinguished road
I agree with outlawz916..Make sure everything is in good shape on the front suspension..Any mustang repo place will carry the stuff you need.Here is an example. http://www.mustangsplus.com/xcart/Mu...andling-Parts/
Old February 7th, 2012, 11:12 AM   #23
TCStang's Avatar
07 GT, 1968 coupe
TCStang is on a distinguished road
What is the differnece in the style of leaf spring? Mid eye, reverse and so on?
2007 GT 339 RWHP and 320RWTQ.
1968 coupe 302
Old February 7th, 2012, 11:32 AM   #24
frdnut's Avatar
1968 sprint
11.82@120.85
It affects your ride height..Reverse would be the lowest,then mid and normal springs.
408W toploader 4:11 detroit locker
Old February 7th, 2012, 12:17 PM   #25
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
I use mid eyes alot they give it a nice look.
Both of these have Mid eyes 4 leafs, with The blue 620 coils in front. The Graba trac 620's dont lower it like these.
Old February 7th, 2012, 12:24 PM   #26
TCStang's Avatar
07 GT, 1968 coupe
ok thanks for clearing that up. Those cars look great.
1968 coupe 302
Old February 7th, 2012, 09:28 PM   #27
[quote=MustangOne;4261659]I use mid eyes alot they give it a nice look.
quote]
That's exactly the look I want. I'll be using mid eyes. Thanks
Old February 15th, 2012, 07:26 PM   #28
I was checking out the Graba trac kits, specifically this one:
620 front coil springs
Performance 4-Leaf Standard Eye Leaf Springs
Upgrade to mid or reverse eye leaf springs for $20 more.
Upgrade to 4½-leaf spings for $20 more and a $14 box charge.
Upgrade to 5-leaf springs for $40 more and a $14 box charge.
1” Front Sway Bar
Upgrade to to 1 1/8" front sway bar for $10 more.
Front and Rear Shock Absorbers
Polyurethane Coil Spring Insulators
Polyurethane Sway Bar End Link Kits
Polyurethane Sway Bar Frame Bushing Kits
New Leaf Spring Shackles with rubber bushings
4 Standard U-Bolts
Pair Of Spring Eye Bolts
You mention that the Graba trac 620s don't lower it like the ones you have on the pictures you posted, would any of the upgrades in the kit help with this? Also, considering I'm on a tight budget, would you recommend any of the other upgrades?
Thanks for the help.
Threads Similar to: Question regarding a 67 Fastback suspension and tranny change
most recomended tranny in a 1969 fastback? patrick1989 Classic Mustangs 9 May 27th, 2011 04:08 AM
30k tranny fluid change 2006GTARPD3 2005 - 2010 10 August 7th, 2009 11:44 PM
Tranny fluid change... 02S281 99-04 8 August 4th, 2008 02:42 PM
Tranny Fluid Change Montanasvt 99-04 21 February 8th, 2008 05:01 PM
Tranny Fluid change?? gt_andy 99-04 4 October 13th, 2007 01:04 PM
