car dies when it gets hot?
Old January 28th, 2012, 11:58 AM   #1
1967 mustang coupe
ma67cpe is on a distinguished road
Send a message via Yahoo to ma67cpe
Ive got a 67 mustang that wont idle when it gets hot. Starts up and run great at first and then once I drive it for about 30 minutes it starts to die. Where to start?
Info I have a 302 with a mild cam. A mallory mechanical distributor. edelbrock 1406 carb and a edelebrock torker 289 intake. It also has a t5 manual trans.
Thanks for any info and let me know if you need more info
Old January 28th, 2012, 05:10 PM   #2
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
It sounds like the coil is over heating. See if you have to much voyage to the coil.
It should have 9 to 10 volts. 12V will over heat it.
Old January 28th, 2012, 09:29 PM   #3
1967 mustang coupe
Ok Ill check it out. I was thinking vapor lock so I went and got an edelbrock heat insulator. Hopefully one of those will work. thanks
Old January 29th, 2012, 10:44 AM   #4
1969 Mustang Fastback
1oldbull is on a distinguished road
I had to put a ballast resitor in my 69 to correct this coil over heating issue.
Threads Similar to: car dies when it gets hot?
Car dies Fast02Pony 99-04 19 April 6th, 2011 08:50 PM
Dies? Stang6er V6 Mustangs 1 January 30th, 2010 01:13 AM
Car Dies UTGT 99-04 11 March 26th, 2008 08:07 PM
car dies Titmouse V6 Mustangs 4 November 29th, 2007 10:18 PM
Car Dies Titmouse 99-04 7 November 29th, 2007 09:26 PM
