70 351C Starts But Will Not Stay Running?
Old January 31st, 2012, 02:25 PM   #1
Look Ma! My First Post!
Fotoman is on a distinguished road
Hello All,
I have a 1970 Mach 1 with a 351C. I installed a complete MSD ignition system, Distributor, Digital 6A Box, & Coil. The Motor ran Awesome & was a Blast to drive. However, the MSD distributor was to tall to install my Shaker Hood Scoop back
on the motor. So, I had to install a Mallory distributor that was short enough to
work with the Shaker Hood Scoop. I really wish that the fine people at MSD would
have warned me about this problem? Anyway, MSD said that the Mallory distributor would work just fine with there 6A Box & Coil. Well, it dosen't. The Motor will start
just fine, however it will Not stay running? Going by there specs all the wires are hooked up correctly. Dose anybody have any ideas what the problem may be? I'd
really like to go for a ride and show this baby off.
Old January 31st, 2012, 08:02 PM   #2
1967 Mustang A-code
unknown
outlawz916 is on a distinguished road
Don't you hate when you work so hard to get something done and when you finish it still doesn't work! You might just have to take it to a shop to save yourself a headache
Old January 31st, 2012, 11:25 PM   #3
Green_6er's Avatar
2000 Mustang 3.8
ehh w/e the mostly stock time is
Green_6er has a spectacular aura aboutGreen_6er has a spectacular aura aboutGreen_6er has a spectacular aura about
are you sure you have the timing set right? also, did you switch from a mechanical fuel pump to an electric fuel pump?
Originally Posted by 6ER THEN I 8ER! View Post
If you don't scrape you did it wrong
Diablo-Eibach-Pacesetter-Flowsound-MGW-BBK
How to paint your rims:
http://www.moddedmustangs.com/forums...ml#post3931042
Threads Similar to: 70 351C Starts But Will Not Stay Running?
'02 V6 will not stay running. Help. mattl2186 V6 Mustangs 13 December 15th, 2011 01:31 AM
88 5.0 sometimes starts but won't stay running cylance 5.0 Mustangs 8 August 28th, 2011 05:59 PM
Got Her Running, But wont stay running...help? Speedstang302 5.0 Mustangs 10 August 28th, 2011 05:58 PM
Please Help! Fuel pump won't stay primed once the car starts. GEMELLI 5.0 Mustangs 4 October 2nd, 2010 02:27 AM
Please Help! Fuel pump won't stay primed once car starts. GEMELLI General Tech 0 October 1st, 2010 04:36 PM
