Radiator: Car Needs to Run Cooler
Old June 16th, 2007, 11:27 AM   #1
BoomerSixZero's Avatar
BoomerSixZero is on a distinguished road
It's around 100 degrees almost everyday where I live.
My car’s temperature gauge reads half way between cold and hot when I'm cruising (which seems fine), but when faced with stop-and-go driving, the temperature gauge gets pretty close to hot.
I flushed the radiator and put in some new antifreeze/coolant. But the problem is still there.
What else could I do to get the car to run cooler in traffic?
Old June 17th, 2007, 09:55 AM   #2
Classic Moderator
Horseshoeing's Avatar
Horseshoeing is on a distinguished road
What kind of fan do you have? Do you have a fan shroud? Do you have a old stock Radiator?
Classic Mustangs are the best! Get one.
Old June 17th, 2007, 11:58 AM   #3
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Is the engine stock or is it modded? Has it been bored? If so how much?
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old June 17th, 2007, 08:47 PM   #4
It looks like an aluminum fan; it has six blades. The radiator is definitely aluminum, quite large. But no, the car doesn't have a fan shroud. Could that be the culprit?
Old June 17th, 2007, 08:49 PM   #5
To my knowledge, the engine isn't modded. It's a 302 w/4 bbl.
Old June 18th, 2007, 05:43 AM   #6
Classic Moderator
I would start with a fan shroud.
Old June 18th, 2007, 10:08 AM   #7
Do you have any tips on installation.? It looks like I'd have to remove my radiator.
Old June 18th, 2007, 11:09 AM   #8
UBY 289 is on a distinguished road
Does it have a clutch fan ?. I replaced the old one on mine and it help .Also I just add a product called Wetter Water and it help with the coolant . Its lowered my temp a bit. I but a shroud on by just removing the fan .
Old June 18th, 2007, 11:57 AM   #9
Classic Moderator
I think I would try to make one so it would be easy to put on.
Old June 18th, 2007, 01:56 PM   #10
It sounds like I should try to make my own fan shroud.... Is this what you have in mind?
Old June 18th, 2007, 02:05 PM   #11
The Wetter Water idea sounds good. Is it an anti- freeze/coolant additive, or a replacement for anti-freeze/coolant?
My car doesn't have a fan clutch. Someone once told me that a fan clutch drains horsepower; so, I have steered clear of it -- for better or worse.
Old June 19th, 2007, 07:16 AM   #12
Wetter water is an additive. Its seems to be helping with me. As for the clutch on the fan I was told the it better for the HP on the motor. I will have to do some looking into this. I removed my Power steering and didn't re-install the factory AC to help the HP. Also could not stand the way the car handle and sounded with PS.
Old June 19th, 2007, 11:43 AM   #13
My car doesn't have power steering or AC either. That's the way it was when I bought it. No power brakes either, but it has aftermarket disk brakes in the front. I'm completely okay without those "power" accessories.
I ordered a fan shroud, but because my radiator isn't stock I'm told I'll have to make my own fan shroud brackets for installation.
I'll give it a day or two of my time to try to figure it out. If not I'll have to go to a radiator shop and have them work on it.
If the problem is still there, I'll try the Wetter Water....
Old June 28th, 2007, 04:04 AM   #14
Grimmy is on a distinguished road
Send a message via Yahoo to Grimmy
I'm in the same situation as you. So I would definitely look into getting an electric fan. It will contiue to move high volumes of air when at low RPMs and even at idle.
Originally Posted by BWAL09
*gets down on knees*
grimmy, will you show me your cockle?
Official MM Zeppelineers. Crew member #1 - Captain
Old June 28th, 2007, 07:09 AM   #15
coolhand is on a distinguished road
Grimmy is correct..Summit has a fan on sale that would work perfect
on your can..comes with shroud..$100.
Engine Ice works better than water wetter..will reduce temp
20 D ...
Old June 28th, 2007, 05:47 PM   #16
1965 Mustang Fastback
nba1341 will become famous soon enough
electric fans work good i have one
theres even a little switch to turn it off
I'm a good boy now.
[COLOR=red][B]slow car club - crew member 7 of 9
[COLOR=White]Mood: Cool :cool:
[/COLOR][/B] [/COLOR]
Old June 28th, 2007, 06:59 PM   #17
Classic Moderator
They are good untill a fuse blow and you don't know it.
Old June 28th, 2007, 07:33 PM   #18
heh i had the problem
and the car would stay on when i pulled the key out and the only way i could turn it off was to flip the fan switch on and off
probally more than a fuse
I'm a good boy now.
Old June 28th, 2007, 10:01 PM   #19
oh my god. did you wire that yourself?
Old June 28th, 2007, 10:15 PM   #20
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
a fan shroud will make a huge difference.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Threads Similar to: Radiator: Car Needs to Run Cooler
Our Sigs Are Cooler Than Yours Drick The Clubhouse 39 November 10th, 2007 10:25 PM
cooler mpboy 99-04 3 October 15th, 2007 10:52 PM
Transmission Oil cooler Mustang Mike 99-04 1 March 5th, 2007 09:41 AM
cooler plugs cdunc24 5.0 Mustangs 2 January 21st, 2007 02:17 PM
C4 Cooler lines New88MustangOwner 5.0 Mustangs 4 December 6th, 2006 09:21 PM
