Discussing 1980 Mercury Capri in the Classic Mustangs Forum. Originally Posted by blackdragon but it is slowly hurting it cause you are oxidizing the ...
Old August 22nd, 2007, 05:42 PM   #21
Site Moderator
TurboLX's Avatar
1990 Mustang LX Turbo
8.67@165.91 mph
but it is slowly hurting it cause you are oxidizing the combustion chamber with nitrous and in turn causes it to instantly rust.(its called flash rust) then you have what is it normally you need 6 lbs of air w/o nitrous in the combustion chamber when with nitrous you only need 1 lbs of air to get everything going.
what the hell are you talking about?
Wiring Diagrams, TSB's, OBD Service Codes and Engine Diagrams Available. PM For Info
Myspace
Old August 22nd, 2007, 06:06 PM   #22
by me?
i sixing 200 six with 300 hp.
Old August 22nd, 2007, 06:12 PM   #23
i have been shooting the juice to my i 6 for four years now and it is still perkolateing.
Old August 24th, 2007, 10:53 AM   #24
blackdragon's Avatar
1979 ford mustang
dude im not going to use nitrous. and im probbaly am going to get a 302cid 5.0 mustang engine from a junkyard and rebuild it.
my 1979 october 9th fox body mercury capri.i've gone through 4 engines now. but im getting a 1993 ford thunderbird with the 302. problem is a tree fell on it.
this was only half on the throttle
Old August 24th, 2007, 06:58 PM   #25
Classic Moderator
Horseshoeing's Avatar
I don't use nitrous. I think it will shorten your life of your engine and I don't need it.
Classic Mustangs are the best! Get one.
Old August 24th, 2007, 07:56 PM   #26
it may be slowly hurting it.but 6 years is very slow.
Old August 24th, 2007, 09:00 PM   #27
Classic Moderator
Can't you melt your pistions if you use to much? Don't cast pistion melt faster?
Old August 25th, 2007, 07:44 AM   #28
i have J@E pistons in my i 6,and i use a mod amount of nitrous.
Old August 25th, 2007, 09:57 AM   #29
Classic Moderator
Reliability concerns
A piston which was cracked due to nitrous use.As with all 'power adders', the use of nitrous oxide carries with it concerns about the reliability and longevity of an engine. Due to the greatly increased cylinder pressures, the engine as a whole is placed under greater stress, especially the parts involved with the combustion chamber. An engine with components not up to the stress imposed by the use of nitrous can experience major engine damage, such as cracked or destroyed pistons, connecting rods, or crankshafts.
Even if the engine is up to the task, severe damage can occur if a problem occurs in the fuel system; an engine running with nitrous oxide depends heavily on the proper air to fuel ratio to prevent detonation from occurring. For example, and especially so with a 'wet' system, if the engine's fuel supply was to be disrupted or cut off, the combined nitrous oxide and air cause the engine to go to a very lean condition very rapidly, which will often cause knocking or detonation. Depending on the engine, this may only need to occur for a matter of seconds before major damage occurs.
Old August 25th, 2007, 03:48 PM   #30
you are right horseshoeing,this is why i run duel blue pumps.i keep them regulated at 6 lbs to insure no fuel failure.the 1 6 i am running has o-ringed head J@E pistons hardend rods and crank .if you start shooting juice to a stock engine ,you are right.it will take a dump.
Old August 26th, 2007, 01:23 PM   #31
sure would like to see blackdragon stay with the i6.they are a lot of fun when people walk up to your car looking for an 8,they lok in and say ,what the!!!!!!!! is that.you know what i am saying.it sounds lile he has built some nice i6 s.
Old August 26th, 2007, 02:41 PM   #32
Classic Moderator
If I had an I6 car with a motor, I would really look into putting in a Toyota Supra I6 in. They are easyer to get the horses out of.
Old August 26th, 2007, 04:36 PM   #33
you are right,htey are easyer to get horses out of.but how many 200 i6 s do you see running with the 8 s, and doing a right good job of it.
Old August 26th, 2007, 04:53 PM   #34
1965 Mustang Fastback
that six you have runs 8's???
Old August 26th, 2007, 04:54 PM   #35
I Touch Myself Sometimes
HMUSN's Avatar
1991 GT
19.83 @ 12mph
^ no... runs WITH 8cyl's
MILITARY CREW
FOUNDER
Originally Posted by itschristorres8 View Post
only bang for the buck is Foxs
SCT Custom Tuning, JLT intakes, Aeroforce Interceptor OBDII gauges and PLX widebands
email joe@tricktuners.com
Old August 30th, 2007, 03:54 PM   #36
1979 ford mustang
yup i have went to a junk yard and guess what......i got another 300 i6 and a 200 i6 incase i wanna keep it original.and the 300 its getting supercharged but the 200 its getting turbo charged.
Old August 30th, 2007, 04:11 PM   #37
which car came with a 300 i6?
Old August 30th, 2007, 05:32 PM   #38
good show man.
Old August 31st, 2007, 07:29 AM   #39
Classic Moderator
F-150 or a E-150 did.
Old September 5th, 2007, 04:01 PM   #40
1979 ford mustang
the 300 I6 came out of believe it or net a ford fairlane. the 200 i6 came out some peice of crap,wrecked pinto i guess or something like that the guy at the junk yard told me the pinto had alot of moddifications to the body and it hit a telephone pole i guess i dint get to see.
Threads Similar to: 1980 Mercury Capri
1980 Mercury Capri Wont Shift blackdragon Drivetrain 1 November 15th, 2007 03:26 PM
1980 mercury capri kill blackdragon Racer's Corner 20 September 17th, 2007 03:54 PM
1980 mercury engine failure big time. blackdragon Classic Mustangs 0 May 10th, 2007 11:27 AM
1980 capri body style? blackdragon Classic Mustangs 5 May 10th, 2007 10:14 AM
1980 mercury capri very loud banging from rocker arms blackdragon Engine 3 February 1st, 2007 09:46 PM
