Oil Change
Old June 30th, 2007, 10:42 PM   #1
BoomerSixZero's Avatar
BoomerSixZero is on a distinguished road
Oil Change
This should be a no brainer but...I'm doing an oil change on my 302 and can't seem to find where exactly I'm supposed to add oil. Is it through the dipstick tube?
Old June 30th, 2007, 10:48 PM   #2
Grimmy is on a distinguished road
Send a message via Yahoo to Grimmy
its on the driver side valve cover. toward the fan there should be a metal cap right on top.
here is mine. it's right in front of the spark plug wires on the right side of the pic.
http://i91.photobucket.com/albums/k2...5/266_6610.jpg
Originally Posted by BWAL09
*gets down on knees*
grimmy, will you show me your cockle?
Official MM Zeppelineers. Crew member #1 - Captain
Old July 1st, 2007, 10:27 AM   #3
Thanks for the quick reply. It did the trick and my oil change is done!
It only took 4 quarts of oil. For some reason I thought it would take 5. Also, what brand of oil would you recommend for next time?
Old July 1st, 2007, 03:46 PM   #4
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
4 quarts that 302 should take 5 quarts but I use motorcraft ford oil but you can use just about anything but I wouldnt use penzoil
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old July 1st, 2007, 10:10 PM   #5
after reading an article in mustang monthly where they tried out several different kinds of oil, i only use synthetic.
Threads Similar to: Oil Change
oil change pfman Classic Mustangs 11 August 17th, 2007 09:59 AM
how do i change my ip nba1341 The Clubhouse 1 August 13th, 2007 10:17 PM
change it up kaizerdan Visual 12 January 11th, 2007 06:15 PM
name change QuEeNiEsTaNg V6 Mustangs 1 December 17th, 2006 07:37 PM
