68' Coupe
Old July 2nd, 2007, 02:18 PM   #1
Look Ma! My First Post!
tatumsilver is on a distinguished road
68' Coupe
A couple years back my dad bought a really beat up 68 coupe that was covered in bondo. He put a bunch of money into it and built the engine. Heres what I was wondering, he loves the car but he hates the handling and he is trying to figure out what would be the best thing to do. Ive heard of transmission swaps from the mustang II but I was wondering what would be the best way to improve the handling.
Old July 3rd, 2007, 01:22 AM   #2
68351w is on a distinguished road
im gonna guess. no power steering? my 68 doesnt. try a new steering box and an alignment....... if that dont work, spring/ shocks... just minor tuneups on things like that. as for the brakes, im going to assume they are drum all the way around. im goning to put 13" drilled and slotted on mine
Whis the the rum always gone? Oh... that's why.
Old July 7th, 2007, 11:16 PM   #3
kit
kit is on a distinguished road
what wheels and tyres is he running?
Old July 9th, 2007, 08:48 AM   #4
Classic Moderator
Horseshoeing's Avatar
Horseshoeing is on a distinguished road
New springs and sway bars are a good start
Classic Mustangs are the best! Get one.
Old July 10th, 2007, 06:32 PM   #5
460brevill's Avatar
460brevill will become famous soon enough460brevill will become famous soon enough
handling
Make shure everything is tight.Set the camber to -.50 set the caster to -.50 set the toe in to 2/32 toe in.Use radial tires.
Old July 21st, 2007, 03:42 PM   #6
themadgnome is on a distinguished road
I would highly recomend starting with all new pollyurethane bushings to help tighten up the old tired front end. Seems minor, but really woke my stang up.
Old July 29th, 2007, 08:23 AM   #7
MustangJoe65's Avatar
MustangJoe65 is on a distinguished road
TCP and Global West make some fantastic suspension parts that will have that 68 handling as good as a modern day mustang. the correct alignment with some good tires will make a big difference as well. i'd also look at the steering box, sometimes they can just be adjusted and it will eliminate the slop in the steering wheel. other times they need to be replaced. you can also opt for a rack and pinion steering to replace the old school recirc ball style. these cars are so light you don't need power steering plus it is only power assist which only makes slow turns easier. if you have it great, but i wouldn't add it.
1965 Prochaged Caspian Blue / Platinum Grey Coupe
2005 Mineral Grey Mustang GT
Threads Similar to: 68' Coupe
T-Top Coupe? bigchimi 5.0 Mustangs 16 February 15th, 2008 09:45 AM
Coupe Question 88mstang 5.0 Mustangs 23 November 11th, 2007 10:44 PM
what should I do (67 coupe) cjcurtis65 Classic Mustangs 4 February 23rd, 2007 08:33 AM
65 GT Coupe with 289 Rolfey Classic Mustangs 9 November 19th, 2006 01:23 PM
