66 Mustang Coupe- Fuse location
Old July 23rd, 2007, 10:26 AM   #1
Look Ma! My First Post!
calebgroup is on a distinguished road
Hi everyone!
I have just found this site, kind of by accident.
I just got a '66 Mustang Coupe, and painted it and bought rims and tires for it. I just realized my rear light is out, and after changing the bulb, i guess the fuse is blown. Can anyone tell me where the fuses are located on this car? I just ordered the owners manual but it wont be here for 7 business days.
Thank you.
Old July 23rd, 2007, 04:43 PM   #2
Grimmy is on a distinguished road
Send a message via Yahoo to Grimmy
The fuse is fine if it weren't, I believe none of your external lights would work. what you need to do is unplug the wire in the trunk and make sure the contact surface is clean and replug it in. I had the same problem a while back.
as for the owners manual, it isn't that helpful. I would recomend this
http://www.amazon.com/Ford-Mustang-2...5219774&sr=1-2
and this
http://www.amazon.com/Rebuild-Small-...836061-8558860
Originally Posted by BWAL09
*gets down on knees*
grimmy, will you show me your cockle?
Official MM Zeppelineers. Crew member #1 - Captain
Old July 23rd, 2007, 07:28 PM   #3
MustangJoe65's Avatar
MustangJoe65 is on a distinguished road
other connections to check are the turn signal indicator ( a commom culprit) and the brake light switch. wiring diagrams are not in the shop manual but are available separate from many mustang shops such as Mostly Mustangs in Hamden,CT or Mustangs Unlimited.
1965 Prochaged Caspian Blue / Platinum Grey Coupe
2005 Mineral Grey Mustang GT
Threads Similar to: 66 Mustang Coupe- Fuse location
98 v6 mustang fuse panel 14perception88 96-98 1 September 6th, 2007 02:49 AM
Fuse pannel location fastang General Tech 1 August 25th, 2007 04:33 PM
66 Mustang Coupe upgrades. ItalianBullitt754 Classic Mustangs 19 August 4th, 2007 11:17 AM
need help locating fuse box on 1996 Mustang! MustangOwner1996 General Tech 1 February 12th, 2007 12:45 AM
